What the game crash log say?world of Warcraft that I have spent too long trying to fix that seriously annoyed me the other night because it crashed at the worst possible time!
When I had a Vega 56 WoW classic used to crash randomly. It was AMDs recording software that was causing it, worth a try.I've just this evening ordered a 4070 ti super after being with AMD for years due to constant crashing in world of Warcraft that I have spent too long trying to fix that seriously annoyed me the other night because it crashed at the worst possible time!
How did you come to the conclussion that it was the GPUs fault? I'm asking cause I'm curious. I played WoW for like 2 months between August and September before i got to bored and never had a crash on Windows or Linux. Sessions could easily be north of 4-5 hours when life permitted. Maybe I got lucky, which is funny, cause I'm always lucky thenI've just this evening ordered a 4070 ti super after being with AMD for years due to constant crashing in world of Warcraft that I have spent too long trying to fix that seriously annoyed me the other night because it crashed at the worst possible time!
In any case, I hope your issue gets resolved, nothing more annoying that constant interruptions when dug into a game.Yeah absolutely no regrets in flipping sides and not funding Jensen's midlife crisis leather jackets any more. But the biggest surprise to me was the drivers and software. The drivers are no worse than Nvidia's regardless to what a lot of people like to preach and the adrenaline software is heaps nicer to use than gforce experienceI have been on Nvidia since well basically since they come out, but noticing the 7900xt and 7900xtx getting great reviews.
So fancy a change as either of them cards are great by looking at the reviews so was wondering if anyone has made the change
and if so was it worth it or did you change back thanks.
Agreed, always go with the best value available at the time!Moved back and forwards a few times and never regretted it once.
It just talks about a driver timeout, it's quite a common issue that I even had with my 5700xt and still had with the 7800xt. Annoyingly it stopped happening for a couple of weeks and now has decided to happen every 30 mins or so.What the game crash log say?
Exactly at the moment with the new windows 11 update when my mate PC comes on screens flick on and off for a few seconds and when he closes the game down the same happens, Nvidia and Microsoft can not work out whose problem it is .Yeah absolutely no regrets in flipping sides and not funding Jensen's midlife crisis leather jackets any more. But the biggest surprise to me was the drivers and software. The drivers are no worse than Nvidia's regardless to what a lot of people like to preach and the adrenaline software is heaps nicer to use than gforce experience
Your problem is elsewhere im afraid. Windows can be finicky at times. Now I'm sure you been through a lot of troubleshooting steps so I will refrain from listing the usual spiel. But to give you an idea of what you potentially could be up against, I've seen this behaviour myself under different scenarios. Once I had to reinstall windows 11 3 times for it to work as intended, we are talking straight format -> install Win -> install drivers --> install steam --> conclude there is something wrong. I sanity checked with a windows 10 install after the second attempt and that worked as it should. I've also experienced the bios on my gigabyte b450 and b550 board go wonky after 4-6 months causing instability where a simply reflash even of the same bios revision and same settings afterwards would fix the issues. That is not to say that AMD doesn't release drivers with instability bugs in them, there has been a few over the years but I most often find the drivers not to be the main culprit. Now my experience is based on the AM4 socket and maybe there are differences with other platforms, that I do not know but I find it highly unlikely. To be frank, I'm so tired of what Windows has become that I'm off it for linux instead where performance and stability has been stellar unless I dabbled in some kernel modificationsIt just talks about a driver timeout, it's quite a common issue that I even had with my 5700xt and still had with the 7800xt. Annoyingly it stopped happening for a couple of weeks and now has decided to happen every 30 mins or so.
.The drivers thing is obviously a personal preference thing. I don't think the Adrenaline software is heaps nicer than the Nvidia drivers (I've never used GeForce Experience).Yeah absolutely no regrets in flipping sides and not funding Jensen's midlife crisis leather jackets any more. But the biggest surprise to me was the drivers and software. The drivers are no worse than Nvidia's regardless to what a lot of people like to preach and the adrenaline software is heaps nicer to use than gforce experience
Driver timeout is just a symptom, not the cause. I'd check your whole computer with variable load diagnostics (like occt has amongst its tests), as Intel CPU issues shown that one could run 24/7 static high load without issues but CPU was unstable on variable load very quickly - resulting in things like GPU driver crashes and other symptoms. I've had ram losing stability and CPU in the past on variable loads (from both camps), often resulting in driver crashes where GPU was innocent. Then again, I had GPU issues as well, so one just has to test everything carefully to be sure, preferably by swapping GPU for test too (same camp I would do to keep test consistent).When it crashes it comes up with a AMD driver timeout message, sometimes I can close the message and the game is still playable, other times the game is unplayable until I restart. Strange thing is my brother has the exact same pc setup and doesn't have any issues.
To be fair if this doesn't fix it I'll know the most likely cause will be the ram as I've changed almost all the parts except that since this issue started.Driver timeout is just a symptom, not the cause. I'd check your whole computer with variable load diagnostics (like occt has amongst its tests), as Intel CPU issues shown that one could run 24/7 static high load without issues but CPU was unstable on variable load very quickly - resulting in things like GPU driver crashes and other symptoms. I've had ram losing stability and CPU in the past on variable loads (from both camps), often resulting in driver crashes where GPU was innocent. Then again, I had GPU issues as well, so one just has to test everything carefully to be sure, preferably by swapping GPU for test too (same camp I would do to keep test consistent).
??? why Ive just come of Nvidia and there is no difference imo what is the problem you are getting.Considering sticking a rtx gpu in my rig as latest radeon drivers make web browsing a nightmare.
For me, 24.9.1 was causing issues with video encoding or hardware acceleration or something. I use OBS to capture clips when playing games and the clips captured after updating were weird... They were noticeably larger in size and when I used the seek feature of VLC, the video lagged and showed artifacts. This didn't use to happen before the update and all my older clips are fine. Literally the last clip I captured before the update was completely fine. I use H.264 encoding btw.
