And this is always my problem. I generally have a bit more 'grunt' than the average person (let alone the average cyclist
) and this is how I break things...like my rear breaks while fitting the new wheels. (Used tool to separate pads, but apparently put too much grunt into this) Took it to my local(ish) shop who fixed it back up. Just needed bleeding I think, which I should really learn to do.
Also, today I moved the saddle forwards a little and tilted a little. Tbh, I hadn't realised the two screws that I thought just held the saddle in place, where how you adjust the angle!
(If there was a dunce smiley, I would use it) Once angled back slightly, it then felt too far back, so now both adjusted.
Haha yeah, lets just say coming from a farming family background and doing a bunch of forestry I've always been fairly brutal to things. Learnt very early on the fine tolerances of aluminium screws - talking computers before cycling, but even then the early years of cycling I'd still shear bolts/screws. Still do occasionally - did a cleat bolt a few months back. Mudguard mount too! I've learnt/been so scared around carbon to always use a torque...
Bleeding is definitely a skill worth learning. With the right tools & a bit of experience can give you confidence to sort things others won't touch. Very likely to adjust a brake between wheel/rotor changes. Fundamentally once you get your head around the parts and how they work together (you're removing bubbles from a line containing fluid) it's a very 'easy' technology to get your head around. A guy I was riding the Wales 200km audax turned up and his rear brake was barely working. Could still (just) spin the wheel with the lever pulled back to the bars! Took me <10 mins to fix. Imagine doing ~2500m of descending without a rear brake - like he was prepared to do!
I found if I'm reseating an old tyre, i have to use co2. If it's a brand new tyre my Joe Blow has been good enough
Unrelated thread updated: House is now Sold STC. Was planning to reserve the new house today but the sales office is bloody closed. Have to wait until Monday now.
So now I feel homeless and Di2-less!
Great news on the house! Hope you've been able to make some progress with the planned one!
Agree with the Joe Blow, mine is superb, although I did get myself an inflator (and it's great) the few times I've had a tyre which wouldn't pop on with the JB the inflator still isn't the golden 'fix', probably working less than 50% of times. Usually a combination of seating and positioning the bead is just as much of a fix. Sometimes I've identified a part of a tyre which is proving awkward to mount, sometimes taking it off completely, then mounting that part near the value hole so it is seeing the most airflow/pressure.
CO2 does work, the blast of air being more than my inflator, but I've had just as many blow offs from it, or it failing to mount. An expensive way of doing things! If the JB and a 1 time with the inflator isn't enough to mount then the CO2 wouldn't - need to find the area of tyre which is refusing to budge - or some other hole in the system - to resolve. Interesting observation - Vittoria rubino tyres massively 'contract' when exposed to CO2 due to the freeze/cold. I buckled a wheel mounting them - the rim wall even getting bent, and it might have been the CO2 which did it.
I thought seriously about the SL8 Expert as you can pick that up for under £5k in some stores. My issue with it is that I don't want Rival Axs, it is objectively heavy for a groupset. I know I could eventually replace the parts, but this is at a cost. I'm also not sold on the nose of the SL8 but I suspect it looks less prominent on smaller frames. The SL7 is a great shout but it's a lower-tier groupset and I'd have to spend money on replacement wheels. I've managed to get the Soloist for £4,700 which comes with Ultegra Di2 and Reserve Carbon wheels which are (apparently) great The only aspect of the bike that needs an upgrade is the handlebars, but this is fit-dependent. It's not worth the RRP of £6,800 (but this can be said about most bikes these days) but I'm happy with the deal.
Also, it's quite nice to have a bike that not everyone else has (I say that, but quite a few people in Cardiff ride Cervelo)
4.7 for the Soloist sounds good for the setup. My SL7 came in at 5.5 but that was with Zipp FC404 (1400), Rapide bars (250) and Ultegra cranks (200) with 2-300 of other bits on there (tyre inserts, vales, sealant etc) and some workshop time. But also the SL7 Comp - so really 'low-middle' of the range (some research - same frame as the Pro, just marginally heavier paint!)
Who sells Cervelo around Cardiff? Probably too late now but always worth checking around somewhere which stocks/builds/sells - especially this time of year (autumn) when next years models are generally released and they're trying to shift stocks. Or even some people trading in... I know someone who changes his Emonda every year and he probably only does 2-3000 miles a year.
my mate is looking to upgrade from SL7 Sworks to SL8 and is trying to sell his frame with Darimo Seatpost.
Beautiful colour. Any idea roughly how much he's looking to shift it for? Only pondering how much a 2-3 year old S-Works frame goes for.
When comparing geometry I have shorter legs so finding frames that I can stand over with both feet seem to be a challenge and always need to size down based on a manufactures recommendation based on my height of 165cm and an inseam of 70cm
If standing over is a requirement, Giant TCR has generally a bit lower or sloped toptube than some others... Cannondale always a bit more upright as they like the triangular traditional shapes more than some others.
But quite a hard thing to know the differences in those smaller sizes between brands. Most reviews tend to be on 56cm frames. Maybe look around some more far-east orientated brands you might find some smaller size details and geometries with a lower toptube option.
I'm a shorter leg & 172cm tall riding a 54cm (height says I should ride a 52 but fit says no) and can't really say I've had any issue with stand over, but I wouldn't stand sat on the saddle either...
Yeah they do look very 'crisp' in white!
What I meant was the older Experts were Ultegra. The SL8 is now Sram rival which technically is a downgrade in spec, without the reduction in price. Hence the similar priced Madone looks like a better buy. However not entirely convinced that the downgrade would translate to any big real world differences for us mortals.
Yup pretty much it. Only the last couple of years seeing SRAM more and more - but thinking specifically Specialized is due to shipping/imports/agreements they're using SRAM more and more.
