Hi,
I’ve been off the gaming scene for quite some time and I never really had a strong understanding of the hardware I was using in the first place.
I played a lot of Total War Warhammer 3 and was always annoyed I could play it in 2k at a solid 60fps. I needed to be able to play it in 2k because I foolishly bought a 2k only monitor. Besides the point.
I’ve pasted my specs below and wondered if someone could give me some feedback on what they think I should do, upgrade my current rig or just sell it buy a new pre-build. I don’t really have the knowledge to build something myself so if I were to upgrade my current rig (which has been in storage for 2 years) I would presumably have to send it to someone.
I have a one terabyte SSD not a 250 GB like it says below but that is the only thing that has changed.
Thanks
Tom
| Case | THERMALTAKE V200 TEMPERED GLASS RGB EDITION GAMING CASE |
| Processor (CPU) | Intel® Core™ i9 Eight Core Processor i9-9900K (3.6GHz) 16MB Cache |
| Motherboard | ASUS® PRIME Z390-P: ATX, LGA1151, USB 3.1, SATA 6GBs |
| Memory (RAM) | 32GB Corsair VENGEANCE RGB PRO DDR4 3200MHz (2 x 16GB) |
| Graphics Card | 8GB ASUS ROG STRIX GEFORCE RTX 2080 SUPER - HDMI, DP |
| 1st M.2 SSD Drive | 250GB SAMSUNG 970 EVO PLUS M.2, PCle NVMe (up to 3500MB/R, 2300MB/W) |
| 1st Storage Drive | 2TB SEAGATE BARRACUDA SATA-III 3.5" HDD, 6GB/s, 7200RPM, 256MB CACHE  |
| Intel Optane Memory | 16GB INTEL® M10 OPTANE MEMORY - USE WITH MECHANICAL HDD |
| DVD/BLU-RAY Drive | NOT REQUIRED |
| Power Supply | CORSAIR 650W VS SERIES™ VS-650 POWER SUPPLY |
| Power Cable | 1 x 1 Metre UK Power Cable (Kettle Lead) |
| Processor Cooling | Corsair H60 2018 Hydro Series High Performance CPU Cooler |
| Thermal Paste | ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND |
| Sound Card | ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD) |
| Wireless Network Card | 10/100/1000 GIGABIT LAN PORT (Wi-Fi NOT INCLUDED) |
| USB/Thunderbolt Options | MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS  |
Thanks
Tom
