I have an old Windows 10 (latest service pack) rig that is going to be completely upgraded once the top two X3D models come up to the market in Q1 2025, maybe keep it as a second system. i7 6850K overclocked to 4.4GHz adaptive all cores, 32GB DDR4 RAM 3.2GHz from default XMP I believe 16-18-18-38 2T to 15-16-16-34 1T), 7900XTX, multiple NVMe and SSD's (all still at 100% and 99% remaining life), Essence STX II discrete audio card used in a 5.1 mode, Seasonic Prime TX 1000 PSU.
Unsure what may have caused this, but I started getting serious FPS drops from let's say 60-70 FPS to 2-5 recently. This happens in both Windows games and emulators (for example Xenia and RPCS3). Steps I've undertaken to troubleshoot and resolve this:
- System file check (sfc), no errors found.
- Loading BIOS optimised defaults. This resets everything to stock - CPU to 3.8GHz, RAM to 2100 or whatever it is, standard voltages, etc.
- The 7900XTX is undervolted and overclocked. Reset to default settings. No change.
- Removed GPU driver with DDU and re-installed from scratch. This has improved things a bit in the emulators, like before that dropping the FPS/stutters almost froze the screen, with the reinstall it still does that but more like a slide show dropping from let's say 70 to 2-5 FPS (no freezing), then returning back to 70.
- Found some Reddit and other threads about disabling Gamebar, including in regedit, which I've done with no change.
- Another "solution", apparently only referring to Nvidia cards in my experience, is disabling driver-specific HDMI sources in Sounds\Playback. Did that with no change too.
- Some posts said that RivaTuner monitoring and especially GPU power on display caused these stutters. Played with the settings and removed "GPU power" from MSI Afterburner monitoring, also completely closed it when gaming, no obvious change.
No FPS drops are observed when CPU and GPU are idle, it starts when there is load and they are always repeated, like almost at the very same intervals (30 to 50 seconds, every minute). Like 70-100 FPS, down to 3-9, then recover to the original level. From monitoring CPU almost never goes to 100%, in the emulators it is mostly from 35% to 90% (according to Task Manager), average and even under load most of the time it is at the ballpark of 70-80% max. GPU power also stays around and up to a maximum of 375W, most of the time less than 250. When I check Task Manager when playing games, although there are other programmes in the background they always use not more than 5% in total, even less.
There may have been FPS spikes/stutters before, but I believe something in my system must have changed recently. It may be a Windows update, a GPU driver change or something else, maybe the motherboard (Rampage V Edition 10) is showing its age and the BIOS is unstable? I am yet to try with a GPU driver from let's say 6 month ago and see if there will be any change. I was initially suspecting something wrong with my CPU (for the emulators predominantly), but I've done many benchmarks and CPU always stays at 100% with no drops, never throttling, by the way this is the same in gaming (CPU package is never above 76-78 degrees maximum in a very well ventilated case). Could it be something with the GPU ot RAM?
Device Manager shows no hardware errors so I will blame it on something software-wise, at least for now. Apart from the older GPU driver, I will make some GPU benchmarks and see if there is a GPU drop too. Judging by my online searches, unresolvable FPS drops seem to be pretty common including on new hardware, but in my case these are repeated, like they happen in a timed manner, like something is pushing the system to its limits or something else happens that drops performance to the bottom for 2-7 seconds, then recover.
Any more suggestions or help, I'd really appreciate it. Many thanks.
