Hi there. No problem. I was a mechanical engineer however spent most of my working life on aircraft wire and cable systems. E.g. radar systems, communications, sensors, weapon systems (not in the forces) basically if it needs wiring and connector designing with routing in harsh areas/conditions etc I was on it.
Have you worked on any old planes/restorations?Hi there. No problem. I was a mechanical engineer however spent most of my working life on aircraft wire and cable systems. E.g. radar systems, communications, sensors, weapon systems (not in the forces) basically if it needs wiring and connector designing with routing in harsh areas/conditions etc I was on it.
