Ancient computer upgrade or not for son?
12 Sep 2012
Hi,
I have an ancient computer sitting around not doing anything. My son is now getting into gaming but only lightly at this stage. Is there anything that I can do with this to upgrade or should I just go fresh build for him? He would want 1080p 0r 1440p for Forza and other racing sims plus tot use for school work.
Intel Core i5-3570K 3.40GHz (Ivybridge)
MSI Z77A-GD65 Intel Z77 (Socket 1155) DDR3 Motherboard
8GB ram
MSI HD 7950 Twin Frozr III OC V2 3072MB GDDR5 PCI-Express Graphics Card
Alpenföhn Matterhorn Pure Edition CPU Cooler
Corsair TX650M PSU
60gb Samsung SSD
1TB HDD
Zalman Z9 ATX case
I told you it was ancient!!!
Thanks
what's your budget?
another 8gb ram to make 16gb, a larger sata3 ssd and a better gpu should be sufficient
something like:
1) another 2x 4gb sticks of ddr3 (£5)
2) a 500gb ssd (£30)
3) a gtx 1070/1660 super/1660ti used (£70-110) would be my go-to
4) overclock the 3570k if not already done so
It is not that bad, it would play A LOT of games just fine, especially anything from the quad core stagnation era between 1st and 6th gen Core.
It would struggle with newer games, but I'm sure you're aware of that already.
What kind of budget would you have for either an upgrade, or a new PC?
Hi,
Whatever it would take to get it upgraded to play Forza etc or a new PC I could probably go up to £1200. If it doesn't need that for a first entry into PC gaming then that would be great. Any specs or links would be great.
Thanks
I would also grab something like a Xeon 1230/1240 v2 off eBay for £15 which is a 4-core 8-thread part. A bit cheaper than an i7 3770/K. It would be a similar chip to what you have but the hyperthreading will probably help in newer games.
which forza? forza is a franchise with quite a number of games, the latest ones are horizon 5 and motorsport
if it's horizon 5 then an oc 3570k is sufficient
if it's motorsport then you'll need a full upgrade
To upgrade your PC for basic playability for newer games, I'd do a combo of what almoststew1990 & tamzzy suggested, with new RAM (16GB minimum), an 8 thread CPU (can be Xeon equivalent, if cheaper) and a decent GPU upgrade. If you wanted a new graphics card, the 6600 would be fine.
This is like a minimal 1080p build:
- For nvidia you can go 3060 12GB or 4060 8GB. For AMD RX 6600 or 6650 XT if it isn't much more. 7600 is also an option. The 4060 and 6600 have the best power consumption, at around 130 watts, but the 4060 is a chunk faster.
- Swap the b-grade motherboard in my spec for a new one.
My basket at OcUK:
Total: £622.91 (includes delivery: £0.00)​
1440p and less minimal, so I'd change bits around a bit:
- You could downgrade to a 6750 XT for £300ish and still get good performance at 1440p, but OCUK don't sell them.
- Nvidia alternative would be a 4070 non-Super, though I think you'd struggle to get one much below £450.
My basket at OcUK:
Total: £958.85 (includes delivery: £0.00)​
£315 (incl. VAT)
£279 (incl. VAT)
£53 (incl. VAT)
£50 (incl. VAT)
£155 (incl. VAT)
£110 (incl. VAT)
£155 (incl. VAT)
£129 (incl. VAT)
these are the minimum requirements for horizon 5
Code:
Processor: Intel i5-4460 or AMD Ryzen 3 1200
Memory: 8 GB RAM
Graphics: NVidia GTX 970, AMD RX 470, OR Intel Arc A380
DirectX: Version 12
Network: Broadband Internet connection
Storage: 110 GB available space
your 3570k is slightly better than the 4460 (more when overclocked)
you'd want 16gb ram really, 8gb is very anaemic nowadays
the hd7950 will not meet the minimum requirements, the 1070/1660 super/1660ti is equivalent to the 980ti
same with your current ssd, you'd want something bigger to install the game on
ie, what i've suggested above will get horizon 5 up and running for the least outlay
something like:
