- 4 Oct 2019
- Queens Park - London
If you open CPU-z, it’ll indicate what brand memory modules the RAM uses.
From there, you can see how aggressive the timings are and get an indication of the die type based on how aggressive you can be with the timings.
Thaiphoon burner is quite loose with its timings, especially with the tertiary timings, compared to that guide that I linked you to so you’ll see better performance and you’ll have a better understanding of RAM after following it.
Timings are grouped into primary, secondary and tertiary timings and each have an impact on performance with primary having the biggest.
I would also write all of the settings down on a piece of paper as you go through the process of overclocking the RAM and get to a point where you are happy with the performance and stop.
Use Testmem5 with the ANTA 777 extreme preset, it’s one of the best ways to check memory stability.
If you want, post your exact memory kit model here and I’ll give you an indication of the memory type to help you out OP.
Edit: wording
Edit: wording
