- 4 Oct 2019
- Queens Park - London
So early adopters of the new ATX spec paid to beta test a new product standard? Great.i wouldn't have recommended it otherwise
3.0 or 3.1 doesn't really matter. the main change from 3.0 to 3.1 is actually the 12vhpwr sensing connector
but in other respects, a 3.0 compliant psu is actually better because they downgraded several requirements in the 3.0 spec, to "preferable" in the 3.1 spec
(ie doesn't have to meet these requirements in the 3.1 spec, whereas they had to, in the 3.0 spec)
whereas a 3.1 12vhpwr cable will fit a 3.0 psu no issues
either way, for a reasonably high-end build with adequate budget, i cannot see why anyone would not get a atx 3.0/3.1 psu
Also, is Nvidia dropping that GPU power connector for a new standard? Thought I saw something about them confirming that the new standard had flaws and was being replaced.
