MacBook Air M1 screen replacement?
18 Oct 2002
Tinternet
A couple of weeks ago, I was cleaning the black border of my screen with a microfibre cloth and came across a very small hard lump - a bit like a shard of a sweet. Wondered what it was and thought it might pick off with a little amount of pressure from my nail. I look after my gear so wasn’t rough with it at all.
Anyway after a bit of an attempt to shift it, I fail and get a green line down the screen and the lump stays where it is. Honestly, it’s minute. Maybe half a mil across.
Anyway, the screen has been getting worse as the MacBook boots but goes dark after a while, even though the keyboard is lit up and still responsive. This is getting more frequent. I can’t really see if being a GPU issue as it has never been dropped or damaged, so assuming it’s something to do with the screen and needs a new one?
Where would you send it or does anybody have any other suggestions of what to do with it. I’d upgrade, but I really like the wedge shape of the M1 airs and it’s been a cracking machine.
No, it expired a few years ago. Should have probably kept it running in hindsight, although by now I’m sure I’d have paid out more than what it’s worth.
We had one without Apple are at my place of work (Air M1 2020). Iirc Apple charged tree fiddy to replace it! Possible with VAT added on top. This was a couple of years back.
rp2000
That’s not so bad then if it includes VAT. I’ve seen other places offering at £250 ish but it’s obviously better to pay the extra and get it done at Apple.
Sorry, to clarify they charged the VAT but as it was a business we deduct it etc. so factor in 20% more
rp2000
Thank you for clarifying though. I think I’ll nip into Apple and see how much it’s going to be.
Let us know when you get your answer?
Might be worth picking up a used screen and manually replacing it yourself.
You could also just run the Mac with an external monitor.
I have been looking to pick up a damaged Mac to repair for my own use but there are a lot of factors in what exactly happened to the unit as to if you can repair it.
