- 15 Mar 2007
I have a case that comes with a hub. The hub contains a ARGB/PWM cable with two connectors off of it. Would I need to connect both of them to the motherboard?
Yes, the ARGB fans included with the case should already be connected to a small PCB in the rear of the case, the PCB is an ARGB & PWM hub, this allows you to connect both the PWM and the ARGB cables from the motherboard to the hub, this way you don't need to connect every single fan directly to the motheboard - as you wont have enough headers on most motherboards.Yes the cable has been located. Just trying to work out the other bit - ARGB/PWM cable has two connectors and I need to connect both (manual simply says connect them).
So I am presuming to connect the ARGB cable to an addressable rgb port on the motherboard and the pwm one to a fan header on the motherboard.
There’s an aura rgb port on the motherboard too - nightmare really
Crazy naming conventions
