Install HA to your new system as normal. Install the Google Backup addon. Restore from the latest backup. Sorted.So my questions is basically, whats the best/easiest way to get the new hardware setup? I use the Google drive addon for backups, so 1 option is to use Balena etcher to flash the HAOS image onto the SSD in the new Optiplex then load a backup. Or could I simply pop my current SSD into the Optiplex or would that not work? Cheers!
So long as you’ve got a backup, HA is very easy to restore to a previous state or new hardware.
cDetailTopMoreOtherSeller,scm-url:1007.40050.354490.0,pvid:bbb6bb93-8a0f-4e73-9718-8be7c673b458,tpp_buckets:668#2846#8115#2000&pdp_npi=4@dis!GBP!45.86!23.39!!!410.93!209.59!@2103956b17307517841286399e0413!12000043066846514!rec!UK!3663160536!X&utparam-url=scene
