Hi
Well im finally going back to AMD (obviously now) after 15 odd years with Intel. I managed to pre order the 9800x3d and so have been looking at motherboards and ram. I have heard and read that 6000/6400 is the sweet spot so mainly looked at those.
I found this I was interested in:
My questions are: is this ok and suitable? I have read that 2 sticks are better than 4 on AMD due to issues. Also for future (ish) proofing Im guessing 64gb will be the way to go.
Thanks
CORSAIR VENGEANCE RGB DDR5 RAM 64GB (2x32GB) 6400MHz CL32 Intel XMP iCUE Compatible Computer Memory - Black
Only thing is on the reviews someone mentioned that its aimed for intel? rather than AMD and then posted a link up to the AMD version, however that turned out to be a 32gb set (2x16gb) and thus I didnt bother going further with that. Im just a tad confused on why its labeled as Intel xmp.My questions are: is this ok and suitable? I have read that 2 sticks are better than 4 on AMD due to issues. Also for future (ish) proofing Im guessing 64gb will be the way to go.
Thanks
