- 2 Aug 2016
- Third Earth
I built mine today, I got some Corsair Expo 6400 and enabled the expo profile, seems solid so far.
Is anyone else having problems getting their 9800X3D to post? I cannot even reach the BIOS on a new Asus Tuf Gaming X670E with Corsair Vengeance 6000 CL30 EXPO RAM. It is in the compatibility list on the Asus website, but gives a DRAM error light immediately on powering on. Never gives a video signal through the GPU, tried also through the iGPU with the GPU unplugged.
I tried flashing the BIOS using quick flashback but that failed despite using a FAT32 formatted empty USB stick which used to work for BIOS updates on my former Gigabyte board. I have ordered a 4GB USB stick to try FAT16 which some people suggested. I had problems getting EXPO to run stably on the Gigabyte Aorus Elite X670-AX so I figured this Asus board would be better. I have just built a matching system with the same RAM and the Asus TUF Gaming B650E Plus motherboard and my old 7800X3D for a friend which booted up fine out of the box without any new BIOS updates. That worked with EXPO straight away.
Does anyone have any constructive suggestions? I am planning to try swapping for my friends identical RAM sticks to test if my sticks are faulty if the BIOS flash still won't work on the new USB stick. Thanks in advance
I also had issues getting my system to boot. Apologies if this is against the rules but this is what worked for me (posted to the ROG forums):Is anyone else having problems getting their 9800X3D to post? I cannot even reach the BIOS on a new Asus Tuf Gaming X670E with Corsair Vengeance 6000 CL30 EXPO RAM. It is in the compatibility list on the Asus website, but gives a DRAM error light immediately on powering on. Never gives a video signal through the GPU, tried also through the iGPU with the GPU unplugged.
Already tried CMOS clear and BIOS Flashback but neither worked. Also tried 1 stick in various slots and the other stick insteadDid you try a CMOS/BIOS reset to see if it would then post with those sticks?
How long have you left it? The system could be doing memory training which can take a bit of time.Already tried CMOS clear and BIOS Flashback but neither worked. Also tried 1 stick in various slots and the other stick instead
Ok thanks, I will try starting with an older BIOS first. My board was made in February 2024 so hopefully I shouldn't have to start too far backI also had issues getting my system to boot. Apologies if this is against the rules but this is what worked for me (posted to the ROG forums):
Re: x670e-e gaming wifi 9800x3d issues
That's what I would've thought too but the system would stay on the orange light for about 2 minutes before shutting itself off. Flashed to a 2 month old BIOS (3024 for X670E-I), which posted fine. Kept moving to a newer and newer BIOS and eventually the latest (3057) also posted fine. Can't...rog-forum.asus.com
I left it 30 minutes, but the system kept shutting down and staying offHow long have you left it? The system could be doing memory training which can take a bit of time.
Looking at that forum above people have gone back 2 bios versions and this has worked.
What bios did you try and go back too? Seems like F31 was the first bios to support the 9000 CPUsI left it 30 minutes, but the system kept shutting down and staying off
I only tried 3057, the latest BIOS on the Asus site. I figured anything older would not be 9800X3D compatibleHow long have you left it? The system could be doing memory training which can take a bit of time.
Edit, what bios did you try going back too? Seems like F31 onwards started support for the 9000 CPUs
Yeah, jesus first 3 or 4 boots mine took around 2 minutes, it was awful... if it wasn't for the debug LED telling me all was good I would have been panicking.How long have you left it? The system could be doing memory training which can take a bit of time.
My first Ryzen CPU (which was the very first ryzen CU) had similar issues, turned out the ram wasn't compatible at all. took me 3 different kits before it would boot at all. I assume things are vastly more improved since those days, but Ryzen has always had a reputation as being sensitive to certain ram. I will only buy kits on the QVL now.I left it 30 minutes, but the system kept shutting down and staying off
Reseating fixed it, important to use the included torque screwdriver that's turn style whatever you call it for this cooler since there's not enough room to fit a normal screwdriver in the center (reused D14 from 2012 build, thought I lost the screwdriver it came with). Temps top out at 74C in OCCT, 86C in prime95, 33C idle using stock settings for now. Still gets quite hot in cinebench though, up to 90C, but no longer smell burning nor 95-97C as it was even in prime95 before. Also used the 5 dot method, funny the instructions that shipped with my free bracket upgrade showed to only do that for AM4 and to use a single blob for AM5.I followed Noctua's instructions: one larger blob in the middle, four smaller ones in each of the corners.
So the friend's CPU is my old 7800X3D which used to work fairly well with my RAM (exactly the same model as his Corsair Vengeance kit), except on my Gigabyte board it would not let me restart on EXPO without needing a CMOS clear. This is a known unresolved problem on the Aorus Elite AX since the overvoltage safety BIOS update last year. I have tried every BIOS since on the board and still cannot resolve the problem, even with manual memory and SOC voltages. Shut down and then a fresh start worked fine. So I guess the RAM "could" be at fault, although I ran Memtest64 several times on my old CPU/board which found no problems and avoiding restarting allowed me to play hours of games at max settings without instability.@IceWolf swapping known working RAM would be a good first step, if that doesn't get you an answer, would they let you try your CPU in their board, or their CPU in your board/RAM?
If not (and assuming you still can't get to BIOS- if you can then I'd try RAM at JDEC specs ( ~4800MHz?))
Basically the best you can do it isolate it to one component which is obviously not working, if all compenets work in one build or another then it's gonna be harder to prove an issue and you may have a bit of a fight on your hands (or at least having to chop and change until you get a combo that works for you!)
That said, are you relying on an old Windows install, or a common SSD between these?- That could be an issue, but less likely (especially if not posting!)
I've got the same kit with a X670E Steel Legend...I have a Corsair Vengeance kit 6000 CL30 I hope it works okay with the MSI x870 Tomohawk.
It's on the QVL list.I have a Corsair Vengeance kit 6000 CL30 I hope it works okay with the MSI x870 Tomohawk.
