Man of Honour
- 21 Nov 2004
This game is bloody amazing. I can't stop playing. It's Skyrim levels of immersion.
Agreed.
Have you tried it with the Optimized Tweaks S.2 mod. I'm only testing in the first section but it seemed pretty nice with frame genI know Frame Gen creates input lag by default but the amount it creates on this game is bonkers, basically unplayable levels of mouse lag with it enabled.
Also, the shader compile at the startup every time... Whoever designed that, assuming this is a UE5 thing? May they stand on lego barefooted every day for the rest of their lives...![]()
It’s worth it to eliminate stutter and loading screens.
16gb RAM isn’t your problem. It isn’t a problem.Just installed it, unplayable FPS on a AMD 480. Uses quite a bit of system RAM, so 16GB machine wouldn't be enough
Just saying. 16gb RAM isn’t causing me any problems.What is then? Would a new mousemat increase FPS?![]()
It will try and use what you got, I have 16gb and usage is only 11gbI have 32gb. But I noticed usage is 16gb-22gb.
I do need a new GPU. Either way FPS is way lower than other similar games. Should be at least double or triple FPS.
People saying it's slow and inefficicient and I agree.
well half of your frames aren't real so yea, in some games it's probably not noticeable but in a fps with fps view and every minute movement moves everything you can see.I know Frame Gen creates input lag by default but the amount it creates on this game is bonkers, basically unplayable levels of mouse lag with it enabled.
Basically this game is unplayable on a lot of 8GB cards as VRAM usage rises over time and saturates the framebuffer. Sounds like a VRAM leak issue.
