Great thanks I'll take a look and have a test. I can always reset the bios if needs be.Well, even easy YouTube Buildzoid (Actually Hardware Overclocking) timings would be vastly superior to those god awful timings. Look up his easy Hynix timings. Given you have an 8000 kit, it’s guaranteed A-Die.
However, I can provide you with some tighter timings myself that ‘should’ run, but I can’t guarantee it. All this assumes that you’re comfortable doing timings in the BIOS.
My suggestions just off the top of my head for A-Die would be -
Set trfc to around 500 and trefi to 65535 asap. Those are killing your latency.
Then TRAS to 52. Set trc to 100. Tfaw to 32. Twtrs to 4. Twtrl to 16. Twr to 48.
RDRDSCL and WRWRSCL both to 8.
Trp to 16. RDWR to 20. WRRD to 6
Put 1.45v into VDD and VDDQ
Yeah I think you're right, updated aida now.Those are some bogus aida numbers - looks too out of date I think - single CCD chips cannot hit those read speeds for example![]()
Yeah exactly. Those timings I’ve given you should be good, but every chip and stick is different. As said, if you want easy timings, just watch Buildzoid.
Try 1.45v as said. If no joy, try 1.5v. I wouldn’t go higher than that though if your case cooling isn’t good.
You should see a significant improvement in latency and 1% lows.
imgur.com
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users.imgur.com
how do I post a picture in the chat posting the above link with https or http doesn't seem to work lol
Changes made:
tREFI 15554 > 65535
tRFC1 1177 > 500
tRAS 126 > 52
tRC 176 > 100
tRRDL 16 > 4
tRRDS 8 > 4
tFAW 40 > 32
tRP 48 > 46
tRCDWR 48 > 46
tRCDRD 48 > 46
tWTRL 40 > 32
tWTRS 10 > 6
tRDRDSCL 14 > 8
tWRWRSCL 34 >16
tRDWR 27 > 20
tWRRD 8 > 6
tWR 96 > 48
tRFC2 639 > 256
tRFCSB 519 > 220
cinebench 24
from 1420 > 1470 multi core
137 > 141 single core.
If you right click the image after clicking your link should be able to copy image link or similar and use that instead. Alternatively when you are uploading it there is usually a get share links or something button where you can grab the bb code. So for your actual link to pic url is https://i.imgur.com/4glIz3x.png which you can add to have it embedded:![]()
imgur.com
2200 is not stable, try 2167. Aida latency should go down, if it goes up or stays the same FCLK needs to be dropped.
Yeah thanks for that. Interesting when I reset the bios trefi was around the 70k mark so when set to auto at some point it decided to up it dramatically. I have the profile saved now I might try and reduce it to 6400 with the built in settings see what the difference isAhh, so my timings were mostly good? Nice. That latency is so much better. Game performance should have increased a lot too.
6400 > 8000 ... unless your IOD can't get you stable 6400 without a lot of VSOC. if you need a lot of VSOC, then going 2:1 is a good approach since it needs a lot less voltage.
6400CL28 on MDie = 1.29vsoc
8000CL34 on MDie = 1.1vsoc
6400CL8 on ADie = 1.28vsoc.
It's all about math and if you are ok running high VSOC, but high VSOC contributes to the overall power envelope, meaning, if you want to OC your CPU you need to have that in consideration![]()
i think i seen you post something similar round 4090 release and you ended up with one lol dont worry though i was the same that FOMO kicks inI'm not buying this time so I can just sit back and laugh![]()
Link to my post or you're making **** upi think i seen you post something similar round 4090 release and you ended up with one lol dont worry though i was the same that FOMO kicks in
hahahahaha ill believe you this time lol roll on januaryLink to my post or you're making **** up![]()
