- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
POP OS is decent tooHow long does that take? Mint is good.
EditRecall has the following minimum requirements:
A Copilot+ PC that meets the Secured-core standard
40 TOPs NPU (neural processing unit)
16 GB RAM
8 logical processors
256 GB storage capacity
To enable Recall, you need at least 50 GB of space free
Saving snapshots automatically pauses once the device has less than 25 GB of storage space
Users need to enable Device Encryption or BitLocker
Users need to enroll into Windows Hello Enhanced Sign-in Security with at least one biometric sign-in option enabled in order to authenticate
Last i heard is you still need what MS are calling a Copilot+ PC (a CPU/PC with AI capabilities) and from what i understand that's not changed....yet.Revising a relatively old thread here, but any more news about Recall?
The last video I watched said that some of the stuff that will enable it is present on all installs / updates to 24H2, since it has been integrated into some of the menus and other Windows components, but that the folders and links aren't active.Revising a relatively old thread here, but any more news about Recall?
I looked online and it seems inconclusive as to whether Recall is now out or not. One source said to go to settings > privacy & security, then look for windows permissions on the main bit of the page. 2nd one down (after General) is Recall & snapshots. Go into there and apparently it can be turned off. Except that Recall & snapshots isn't listed for me. Doesn't mean it's not on my PC though as it could have just moved to another settings page or named differently.
I know Recall is meant to help with search, but file indexing, recently-used-files jumplists and browser history are all sufficient for me for searching my computer and web sites. Something that is recording my screen on top of this seems over the top for me.
Recall is already in Windows 11 version 24H2 for all users and embedded in to Windows explorer.I read it's not been offered unless you have a copilot+ PC. It's probably just a matter of time till they make it mandatory. Think I will setup a Linux OS with a locked down Windows VM for work stuff.
At work we had this issue a lot when Windows 11 first came out.Had a machine running Windows 10 which I was more than happy with and had to continuously decline the upgrade to 11. Was away for a few weeks whilst it was running and when I came back, it was powered off. Turned it back on and it had decided entirely of itself to upgrade to Windows 11, without any prompts or authorisation to do so.
People where leaving their servers on (Windows 10 PCs) and over the weekend it would say to upgrade to Windows 11 and because no one was there to say "no" it updated anyway so when they came in Monday nothing was working or software was broken due to going to Windows 11
Exactly, even more so when Windows 11 first came out the software was not ready for it so after all that sometimes issues where fixed and others it was rolled back to Windows 10 which added more down time for them.My machine was a home server running very basic things like Plex and I was lucky that I wasn't impacted that way. But it definitely occurred to me that people would be caught out, in exactly the way you described.
Brute forcing shut downs and restarts for updates was one thing but to install a different OS, when it gets you out of the room for long enough, is actually ridiculous when you think about it.
I know this is far from a new issue as I've seen multiple people hacking their OS to prevent such updates but that in of itself is something that you shouldn't have to do.
