That's really great performance! You can pretty much say you've bested that game in terms of CPU requirements.....
You're going to need a new challenge.
Yeah, GPU utilisation is right up there, not quite at 99% but it's high enough that it's probably not the best CPU benchmark anymore. Probably need to drop down to 720P or lower.That's really great performance! You can pretty much say you've bested that game in terms of CPU requirements.
Try -025 or -30 PBO and set +200Mhz for max boost override, scalar x10, and set PBO limits to Enabled. This should pretty much max out performance using PBO and you'll get clock speeds up to 5.425Ghz. A real quick and easy overclock that should be plug and play on all samples.So just got my CPU this week and getting back into OC
I assume PBO is good for beginners and doing the following is right
PBO enabled +200mhz -20 on the curve and x10 on the scaler
CD23 is reporting 23800 pts and temps 82 with a AIO in a mini-its build
For the run below, I was running 5.8Ghz. I'm not sure what I ran back then, but it was lower. Probably 5.7Ghz or so.what are your cpu over clock settings? I'm getting 250 fps but have 3090. At 1080p low I thought it would not use the gpu as much but i see it at 98% usage.
With AGESA bios features provided to manufacturers by AMD directly the options are the same across boards, just the location and setting names might be different, but I'll get you some screenshots of PBO settings to start with in this specific BIOS/BOARDAnybody have a basic guide to X870E MSI Carbon BIOS to setup the 9800X3D with a 200mhz increase (PBO, curve, scaler settings and anything else important). I can find all settings but they are worded slightly different compared to ASUS BIOS for example and there are many other options (like 10 presets for PBO enabled).
Thanks
Popped this in the boards thread:Anybody have a basic guide to X870E MSI Carbon BIOS to setup the 9800X3D with a 200mhz increase (PBO, curve, scaler settings and anything else important). I can find all settings but they are worded slightly different compared to ASUS BIOS for example and there are many other options (like 10 presets for PBO enabled).
Thanks
I've never used one to be honest, Robert. I tried an MSI board once, B Grade from OcuK, that was enough to remind me never to switch from Asus. I can't really offer any recommendations on alternatives unfortunately.@LtMatt any word if GB boards are good for oc or still clowny? Was looking at Pro ICE for IO
I have the Pro Ice and an Asus motherboard. The pro ice is running a 7800x3D atm but tommorrow I will switch it over to teh 9800x3D@LtMatt any word if GB boards are good for oc or still clowny? Was looking at Pro ICE for IO
Check you didn’t set curve to positive by mistake.X870E MSI CARBON. Tried PBO enable, +200mhz ,-30 curve, x10 scaler.
CB23 no change 22960 multi, CPU speed still 5.2Ghz, temps up about 8-9 deg C, now max 87 Deg C.
Something I'm missing in BIOS or forgot, or this is normal?
Cheers
What about setting GFX curve by mistake...I put that here in case anybody else isn't careful!Check you didn’t set curve to positive by mistake.
Some workloads will not hit all core max boost OC. You can check the max boost (and everything else) with hwinfo64 (just load sensors only)X870E MSI CARBON. Tried PBO enable, +200mhz ,-30 curve, x10 scaler.
Cheers
