Oh no, feel free to yapIn a Cessna 172, use 20deg of flap on base and then 30deg on final. Ensure your speed is in the white arc/range before you bring in the flaps. Re-trim after flap changes. On final approach, keep the runway about 1/3 of the way up the windshield, keep a steady approach speed. In a Cessna 172, that would be about 65kts, bringing the speed back further once you are about to transition to touch down when over the runway threshold. Use pitch to control your speed and power to control your height. When approaching or over the runway threshold (depending on how high you are) bring the power back to idle and gently pitch up (flare) and let the main wheels touch the runway, followed by the nose wheel. If you float, just let the aeroplane keep flying, hold your pitch. It will touch down when it’s ready, don’t try and force it down. Look to the far end of the runway to maintain directional stability as you touch down. Brake gently to slow down to a speed where you can safely vacate the runway. If you are not happy, apply full power and go around, raising your flaps in stages.
In a light GA single engine aircraft the approach path may be steeper than the standard 3deg glide slope that the runway side PAPI indicators provide at large airports, so don’t chase the PAPI. This is a good thing as it means you won’t be at the back end of the drag curve in the unlikely event of an engine failure on final approach. Think energy management.
NB: just realised you wanted a tutorial before I started yapping!! I’ll look online later and see what I can find and post them.
Two things from that, still not got my head around "pitch for speed, power for height" and it's the retrimming in the middle of everything as well. Also I think I need to take control from AP earlier to give me more time to get the plane settled.
