Random 3D printing chatter
Morning all,
I have tried to find a local 3d printing service but to no avail, so trying the trusty OCUK forums.
would anyone have the capacity to 3d print something VERY small for me? I have the FreeCAD (Link Branch) file. By small I mean 1.5mm thick "shims"?
would appreciate any support - Thanks in advance.
Problem with something very small is the effort taken to get to a good print.
I'll happily have a look if you want to send it to me through trust. Only have PLA+ in white at the moment, will probably be ok but if it's going to be under pressure (between a bolt and object) then it may struggle.... Need to check the use case.
Hi bud - thanks for the reply
Not much pressure, its for Shims for a coffee machine drip tray!!
Ill drop you a trust
Just acquired a QIDI Q1 Pro (found with a significant discount in a rainforest). Coming from a CR Ender 2 I have to say I'm impressed. This thing really is just plug in and play.
Started scratching the surface of Fusion360. For context, last time I dabbled in CAD words like "Pentium MMX" were still in use, so to see how far it's come is quite something. This will be one hell of a learning curve but one I will thoroughly enjoy :cool:
For those with recent bambu printers, how long did yours take to get delivered? I finally bit the bullet at the weekend after years just looking at 3d printers, now I'm itching to get stuck in with a whole programme of prints already planned but nothing on dpd as yet.
Recently bought a Geeetech Alkaid for like £80. Didn't really do my research so it's not anywhere near as easy as I'd hoped plus I haven't printed anything yet as I didn't realise how toxic resin was and now need to clear a space in the shed and keep it warm
How is your learning going?
Any of you lovely humans fancy making me a hook for my Dyson stick 'long bit? I've found this thing that looks alright - unless anyone has found better solutions?
Making space for my own 3d printer soon :D
Many thanks
Built3D Wall Mount Holder for Dyson Stick Wand Tube V15 V11 V10 V8 V7 Absolute Complete Extra Animal Outsize Detect Stick Vacuum Cleaner, Wall Hook Hanger and Storage, Black (016-B) https://amzn.eu/d/bLKBiRu
(I have a Dyson v6)
Many thanks
(I have a Dyson v6)
Go on these sites and have a nozy:
See if you find anything that fits the bill and stick up a link. I'll do it for the cost of material + leccy + postage.
Or you can put your big boi pants on and come for a beer and collect it :D
Anyone got a soldering iron? Are the £20 ones on the rainforest any good? I want to do some heatset bits to take on bigger projects like the V Spooler but I've never soldered before and I don't know what's good
If you have a decent usb c charger you can get one of those pencil ones. Should be cheaper as it doesn't have a power supply
I've one of those, they are very good. it'll run off a cheapish power supply or a laptop one as long as it's USB C, they also use barrel adaptors.
