NVIDIA RTX 50 SERIES - Technical/General Discussion
Two whole years of luxury… of not using DLSS and barely seeing any difference :p
… but it’s never something you had to consider so it was worth it!!! :eek:
I find dlss only useful when sharpening can be set. Too much and it looks artificial, too little and it's too soft. Also my screen could only max at 120fps.
My new 77" G4 can do 144fps at native 4k! Every option is on the table lol.
I think for some people it's the feeling of having the best of the best. Its why people buy new phones every year. Or a new car every year. Sometimes buying things dont make a tangible difference but if it makes you happy it makes you happy. No point earning money if you're just going to sit on it until you die. Spend it on the things that make you happy. But there's also no point spending money if you're going to regret it every time you look at what you bought. If you know you won't regret it then don't let anyone stop you.
Where did you get the number from? For 2% margin no corporation would even bother to sell anything, it's ridiculous.
Its not, these are the times when you fall that much behind. God knows how good the MCM design was, if it actually saved money or not.
It also encompasses console chips, but still, pretty low.
It does get a bit silly when you think about it. You could get the second most powerful GPU in the world *AND* a grand in your pocket to upgrade literally any other aspect of your setup or go on holiday for a week lol.
I had to laugh after reading the above post and then seeing the later post below :cry:
Mountain of salt as the source is Reddit...
The 5050... hold on not that I'm intrested in the purchase of it mind though this could mean that Blackwell is backwards compatible with GDDR6(X?)
Looking at the 5090 spec in that list compared to the 5080,
Dam that 5090 going cost a fortune :(
  • Sad
Reactions: G J
Oof... They're really compensating for the anemic cheaped-out specs on the 5080 by bunping mem speeds to the roof. That card is going to look ok in some situatuons, fall on its face in others -- it's a very unbalanced config. I wouldn't touch it with a 10m pole. Keep a keen eye for cherry picked benchmarks from nV and reviewers.
  • Sad
Reactions: G J
I use this line of thought every time I'm in the maccies drive through and about to order 50 nuggets.
5090 is not going to be in same league as the 5080, thats a widely held assumption, so idk if thats the correct way of looking at it
While I agree, what kind of performance uptick would you need for >£1000 differential?
There's lesser vRAM, but I'm looking though it strictly from a gaming perspective and not and edge use case I.e Skyrim with hundreds of mods, MS flight Sim etc
Ok, so what you meant by that is operating margin of the whole gaming department for the Q3 - which isn't the margin they set on GPUs for example (2 very different things). It doesn't seem to have anything to do with RND done on these years earlier either, nor with MCM cost. It only cares about sales numbers and current expenses - it might as well be because their current RND of this department is funded heavily and eating all of the income. In other words, it hardly tells us anything about actual performance of that department in a given quarter by itself.
