Difference between midi and pro configurator
21 Dec 2024
UK
hello, i configurated two Pcs one with the AM5 midi config and one with the AM5 Pro config, ive selected nearly the same specs on both except the Pro config comes with 1000wattage psu and 360mm aio BUT the price difference is nearly £400. Can anyone please tell me why?
MIDI CONFIG :
OcUK Tech Labs AMD Ryzen AM5 Midi Gaming PC Configurator
SKU SYS-OCT-00044
  • 1x Phanteks XT Pro Ultra ATX Case Tempered Glass Window, White
  • 1x Build Stock AMD Ryzen 7 9800X3D Eight Core 5.20GHz (Socket AM5) Processor -
  • 1x Asus ROG Strix B650-A Gaming WIFI (Socket AM5) DDR5 ATX Motherboard
  • 1x Corsair Vengeance EXPO/XMP 32GB (2X16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit
  • 1x Lian Li Galahad II Trinity SL-INF AIO 240mm ARGB CPU Water Cooler - White
  • 1x Sapphire Radeon RX 7900 XT Pulse 20GB GDDR6 PCI-Express Graphics Card
  • 1x Corsair RMe Series RM850e Fully Modular Low-Noise ATX Power Supply v2 (CP-9020263-UK)
  • 1x Crucial T500 2TB NVMe PCIe Gen4 M.2 Solid State Drive
  • 1x Build Stock Microsoft Windows 11 Home Advanced - Systems
PRO CONFIG:
  • 1x NZXT Kraken 360 White RGB AIO CPU Water Cooler - 360mm
  • 1x Corsair RMe Series RM1000e Fully Modular Low-Noise ATX Power Supply v2 (CP-9020264-UK)
  • 1x WD Black SN770 1TB SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS100T3X0E)
Nice prebuilt specs there, what sort of premium are you paying for prebuilt I wonder, those specs are what I’m looking at but was going to build my own, but I’m still tempted by prebuilt.
Its not a a prebuilt one, i picked the parts myself. The midi config came to 2.1k and the pro config was 2.5k
The difference in actual cost is say roughly in parts £100 for the larger PSU and 360mm cooler so it's £300 more according to your calculations.
If your asking why then other than overpricing/underpricing I can't tell so ask Overclockers and if you wish to purchase then go for the cheaper that's makes most sense.
The cost for parts from the store is
Midi - £1959.91
Pro - £1997.91
Not sure how much they charge to build it, but going by the above prices they should be very similar.
The config price for the midi is 2.1k and pro config is 2.45k
Well if the midi cost price according to @freddie64 is £1959.91 that makes labour charge for the midi pre build pc a £140 which is an absolute cracking deal as Overclockers charge £300 + 3% parts to custom build.
Enjoy the pc if you decide to buy one.
Should have add the baskets to my post yesterday. (both include postage)
Midi.
My basket at OcUK:
Total: £1,971.90 (includes delivery: £11.98)​
Pro.
My basket at OcUK:
Total: £2,009.89 (includes delivery: £11.98)​
