- 22 Oct 2012
To fix the issue, you don't need to remove or stop afterburner starting.That's a shame as I really like afterburner. What are the alternatives? I have only ever used Rivatuner and afterburner.
Also years ago when I had a 5950x I remember using a program where you could test each cores individually after setting what negative offset. I can't remember the name of the program. Does anyone know the name? When I got time I am going to go through the cores one by one.
Just uncheck GPU power monitoring from Options ==> Monitoring ==> GPU1 Power and Power % (and GPU 2 Power and Power % if you have integrated graphics too).
