This is quite confusing tbh.
Short cycling won't cause the house to be cold and be unable to get up to your desired temp (E.g. 20degsC). As it's a newish house, it will be insulated well, so even with fairly small rads and a high flow temp (70degsC) it will heat up quickly and easily with the above setup. Unless the house is massive, an average 150m2 4 bed detached probably has a heat loss of 5.5-6kW MAX on a -3degC day. Your rads would have to be A4 sized single panels to not be able to heat the place up.
Are all the rads warming up and feeling very hot to the touch (use back of hand)? You ideally need to find out what the temperature of the water is entering and leaving the rad, get a cheap IR thermometer (wrap the pipe in black tape to help get a point reading).
I wouldn't worry about boiler range rating settings or flow temps until you can confirm to us the rads are working and the house gets up to 20degC internal temp and stays there. Start with one thing at a time to troubleshoot, rather than trying everything under the sun where you'll just get confused and not end up figuring out what the main problem is.
