In my case I tend to wander back to my phone planning to kick it off, forget and then wander back to the washer a couple of hours later wondering why it's doing nothingHonestly I think the WiFi is a bit of a hassle.
It just adds another step to the process. Where you’d normally put the load in the dryer, set a delay for (finish time-time taken) and start, you now gotta grab your phone, open the app and do it in there
And that’s assuming it works properly.
this looks simpler than the samsungMine has wifi but it’s a gimmick I stopped using it and just use the controller on the front. Was the same with the dishwasher for me as well. Used it at the start but never again.
It also has what they call a self cleaning condenser. I just need to hoover out the double filter thing at the front. I do it after every use.
Bosch Series 8 WQB246C9GB Freestanding Heat Pump Tumble Dryer, 9kg Load, White
Buy Bosch Series 8 WQB246C9GB Freestanding Heat Pump Tumble Dryer, 9kg Load, White from our Tumble Dryers range at John Lewis & Partners.www.johnlewis.com
They're different, though yes both are condensing the water - condensers use a heater, which condenses into hot water that you either drain away or empty the tank after using.I though heat pump was by design also condenser?
We went heat pump, great decision, the best part is emptying the water tank and seeing how much water DIDN'T go into the house. If you enjoy the pleasure of emptying a dehumidifier you'll love a heat pump drier![]()
I'm not seeing that price anywhere?Just got a heat pump one. A Hisense DHQA902U for about £320 after discounts/cashback. 9kg, auto sensing drying etc, reversing drum and 2 years warranty.
Was sick of having clothes horses in the house everywhere and adding to the humidity inside.
Only had it a couple of weeks but it's been great so far.
Loads more efficient than a regular one. Will probably make back the extra spent over a cheap vented one very swiftly.
I wanted a heat pump dryer but unfortunately it can't be used in the conservatory as its far too cold.
I know it's not the same and I'm sure the manufacturer will list its operating temp - but my split AC system is a heatpump and I have it set to 22 degrees ATM (the inverter lives outside)I wanted a heat pump dryer but unfortunately it can't be used in the conservatory as its far too cold.
The most annoying part of my samsung one is this brushing!this looks simpler than the samsung
the samsung has the double filter in a similar position, then there is also the HE which needs brushing, () not a great design, I think the bosch ones can be removed and cleaned better
 Find sometimes it's just a little bit damp in there and just becomes a nightmare to clean fully.My Samsung Heat Pump tumble dryer is nearly 10 years old now (bought when they were quite new tech) and it's been ace. Only thing is, it's gotten quite noisy and there is this ticking like something is worn out/rubbing.
I've been over due to take it apart...stare into its insides like I know what's wrong...leave it in bits over a weekend...receive a telling off from the Mrs for "playing" with things... only to put it back together Sunday evening with only cut knuckles and sore knees to show for it.
You'd be pretty special not to get a heat pump. Mine costs pennies to run and its on all the time.
Edit: data
<1kwh for a load. Where it exceeds 2 is where it has been used 2 or 3 times in the day.
Mine is a very similar design but Hoover branded (I suspect nearly all of them are made in the same place). It has a square of foam over the heat exchanged you can pull out and brush the fluff off. Would be easy to just cut a square and add it to yours.The most annoying part of my samsung one is this brushing!Find sometimes it's just a little bit damp in there and just becomes a nightmare to clean fully.
can look at earlier heat pump thread including below vid showing test energy values. 0.6kwh+
( the ones that have an electrical heater - give better efficiency if you want it in a garage/cool area, otherwise they are taking some heat from the room.
additional wear on clothes due to extended drying period, even though it is cool is still an issue )
e: hybrid was the newer gen
I've not replaced my TD with a heat pump one, as I found it to be a false economy from a cost only perspective, but if you are buying new it makes sense to go that route.
120 mins, on low heat (I never use high, unless finishing my goose down duvet) pulls under 2kW, and not constantly, so given I always run it off-peak it's less than 14p per load (could run if from battery too). I reckon it would take 25 years for a heat pump to make an dent with the savings, and I'd be scrapping a perfectly good tumble drier, which isn't very environmentally friendly at all. The drier has now got to be nearly 20 years old, or older, I forget, how often does the R134a refrigerant in the heat pump drier need replacing?
