- 21 Sep 2020
this looks simpler than the samsung
the samsung has the double filter in a similar position, then there is also the HE which needs brushing, () not a great design, I think the bosch ones can be removed and cleaned better
It once popped up that it wanted to do a clean cycle. I had to put some warm water in the tank and disconnect it from the drain so it was a closed circuit and run it through the clean cycle and a bit of fluff, I wouldn’t say a great deal ended up in the water tank to be thrown out.
Brilliant machine. We love it.
