- 19 Jan 2007
- Up a Tree
Hello everyone,
I am experiencing bufferbloat on my BRSK 150 down/150 up connection and I am hoping you can give some advice.
Should I contact BRSK about this. Will it affect my speeds if I do.
Or would you recommend I spend money on my own router instead of the BRSK supplied router.
Here are my results:- https://www.waveform.com/tools/bufferbloat?test-id=6fe27de2-f857-4ad8-913f-10eabedca0cf
There is only me that uses the connection, so does it really matter that I am getting bufferbloat?
Thank you for reading.
