It's like why spend £50k on a sports car when you can get a ******* for £500? Both get you from A to B...I think when the prices land it might put people of like myself cant justify paying 2500 ( hopefully ) for a bit of tech ..
It's in the partner showcase threadJust looking for the Swedish prices on Asus cards but not having much louck, could you post them please?
I dunno if they are better value? Maybe versus the silly AIB prices mentioned in the thread, but not versus the 5090 MSRP. Prices on ebay are around £1400-£1550 depending on the model for 4090, reviews point to the 5090 being around 30-35% better, so the MSRP of the 5090 in line with that increase, and you don't have to worry about the used aspect.How about a used 4090 lot cheaper than new and better value against the new 5090
plus no warranty. I think if you want a used 4090 the time is now though. Those that don't get a 5090 on launch might look to buy one. Plus before 5070 reviews come out you can low ball fb market place seller and send the screen shot of the 5070 matching 4090I dunno if they are better value? Maybe versus the silly AIB prices mentioned in the thread, but not versus the 5090 MSRP. Prices on ebay are around £1400-£1550 depending on the model for 4090, reviews point to the 5090 being around 30-35% better, so the MSRP of the 5090 in line with that increase, and you don't have to worry about the used aspect.
I'll likely just wait for launch to try for a FE. I managed to get a 3080 FE on launch above all odds, so maybe there's hope.
Yea, well I think I'd rather just wait and get a card after launch if I whiff than go for a used 4090 anyway. I'm not entirely against buying used, but probably not for a GPU at the current prices. I think the current prices are really great for anyone wanting to sell since they've not lost much value in the 2 and a half odd years they've been around, but I think for the buyer they're less of a deal. That said I think the new prices aren't massive deals for buyers anyway, hah, but indeed you at least get some security with warranties.plus no warranty. I think if you want a used 4090 the time is now though. Those that don't get a 5090 on launch might look to buy one. Plus before 5070 reviews come out you can low ball fb market place seller and send the screen shot of the 5070 matching 4090![]()
I am not talking about eBay. Generally you fill find members here will start dumping their cards the closer we get. If the used aspect worries you check their feedback and do your due diligence and ask all the questions you need to put your mind at rest and in my experience. most of them will still have warranty.I dunno if they are better value? Maybe versus the silly AIB prices mentioned in the thread, but not versus the 5090 MSRP. Prices on ebay are around £1400-£1550 depending on the model for 4090, reviews point to the 5090 being around 30-35% better, so the MSRP of the 5090 in line with that increase, and you don't have to worry about the used aspect.
Agreed a used 4090 is probably the best bang for buck card right now on the market, if you can snag one for £1200 or less it's a steal tbh.I am not talking about eBay. Generally you fill find members here will start dumping their cards the closer we get. If the used aspect worries you check their feedback and do your due diligence and ask all the questions you need to put your mind at rest and in my experience. most of them will still have warranty.
The prices have dropped somewhat from members but it varies from member to member. Only last week an Aorus master sold for 1100. That is way better value than any MSRP 5090 out there.
There is no sceanario that a 2k FE is better value than a 1100 or similar priced 4090 and less so the higher end AIB's 5090.
Well I would never describe any halo product past or present in the same sentence as bang per buck cos that not the point of the card. But then again I think the appeal of the 4090 has managed to increase. Simply because people can't get past the mindset of 2k starting and only what 30% faster rasterisation uplift. So in comparison it seems like bang per buck.Agreed a used 4090 is probably the best bang for buck card right now on the market, if you can snag one for £1200 or less it's a steal tbh.
I do not have access to the members market here either way. I think it requires like a 1000 posts or something? I'm not sure.I am not talking about eBay. Generally you fill find members here will start dumping their cards the closer we get. If the used aspect worries you check their feedback and do your due diligence and ask all the questions you need to put your mind at rest and in my experience. most of them will still have warranty.
Beacause the 5080 = 4090 is just false, there's a reason those reviews come out a week laterHow are you arriving at this conclusion if a 5080 (for £979) is equal in performance to a 4090 in raster?
The 5080 will have the latest DLSS (may or may not be important to you).
The only thing the 4090 will have over 5080 is more VRAM (but the 5080 has GDDR7 which is faster than 6X).
The Op was talking about 5090.How are you arriving at this conclusion if a 5080 (for £979) is equal in performance to a 4090 in raster?
That 5070 = 4090 was pure marketing gimmick hype, the 5080 is very slightly beefed up from the 4080 Super, and the node process change isn't resulting in more efficient cores, where the 4090 has 50% more cores. In rasterisation I'm expecing the 4090 to be about 10-15% faster (at the minimum) and the only way to potentially equalize it is if you use the 4x MFGThe 5070=4090 was false. Its likely the 5080 equals (or very close) to 4090 performance.
On an inferior 256bit bus so the 4090 actually has faster ram overall(but the 5080 has GDDR7 which is faster than 6X).
Anything below £1200 for a 2nd hand 4090 will be good when the 50 series is released.
5080 will fill the gap between 4080 super and 4090
