Poor
NVIDIA official GeForce RTX 50 vs. RTX 40 benchmarks: 15% to 33% performance uplift without DLSS Multi-Frame Generation - VideoCardz.com
NVIDIA shows more RTX 50 performance figures The next-generation GPU architecture explained a bit more. NVIDIA has disclosed new performance figuresvideocardz.com
NvmIf you want the TL;DR version:
NVIDIA Confirms RTX 50 Gaming GPUs Native “Non-DLSS” RT Uplifts:
RTX 5090 30% Faster Than 4090,
5080 15% Faster Than 4080,
5070 Ti & 5070 20% Faster Than 4070 Ti & 4070
Poor
5070 is a DOA GPU like I predicted, 12GB and little to no improvement in rasterization over a 4070. The only improvement will be in RT games where it should perform like a 4070Ti and in AI workloads if you need that.
If it wasn't for VR I would honestly be sticking with my 3090FE. I think a used 4090FE is my target, anyone got one coming up???
I would argue that even the 5090 is a disaster. It's at least £2000. How is this now acceptable?The 4090 had the benefit of a much smaller process node, allowing vastly higher number of transistors (and thus cores, shaders etc) combined with a big bump in clock speeds.
With the 5090 only getting a marginal decrease in process size, it was never going to be able to match the 60%+ uplift of the 4090.
Depends on the market your looking at it from a current 40 series owner I would think5070 is a DOA GPU like I predicted, 12GB and little to no improvement in rasterization over a 4070. The only improvement will be in RT games where it should perform like a 4070Ti and in AI workloads if you need that.
from anyone 30 series or before / new system builders it will be fine and run like a 4070ti in Raster for under £550
your right a a 5070 is not worth it from a 3080 still only a 30%From someone that's currently on 30 series , I'm more interested what AMD offers in the £500 range, 12gb £500+ in 2025 yeah no
