Benchmarking vid starting in a few minutes - could be interesting.
Might just be the same information repeated, if so, apologies!
Edit - it’s actually quite a good vid, worth a watch.
This guys videos are never good
4090 owners will not lose a couple of hundred quid on a 5090 upgrade noIf you need to sell to buy or are worried about losing a couple of hundred quid on resale then its questionable whether you should be buying a 5090 in the first place.
Time will tell .New Nvidia benchmarks claims:
5090 is 30% faster than 4090
5080 is 15% faster than 5080
5070 is 20% faster than 4070
Can't beat physics Jensen
Well said.I think it's very clear that the 5xxx series is aimed at those on 3xxx or below GPU's, for NVidia anyone on a 4xxx series upgrading is simply a bonus. I'd say even those on the 3xxx series want to consider if they need to upgrade, if the games they play are at acceptable framerates with almost everything on max settings then I'd strongly consider holding off.
I do wonder if the 5xxx series might be short lived and we'll end up with 6xxx series sooner than expected, there are rumours circulating of them bringing the launch forward although these seems more likely with the ranges intended for datacenters.
1999 I fondly remember rushing down to Dixon to get the 3DFX Voodoo 3 AGP for £180 brand new at release, no queuing just in the shop get graphics card and off home to play on Quake 3 Arena on a 75hz crt monitor , much simpler times back thenThe only 1999 I want to see when it comes to graphics cards is the year. $300 for a DDR GeForce 256, and I was playing games with an integrated ATi Rage Pro that used 8MB of the system RAM, and couldn't have been happier...
I was all set to grab a 5080 but if that's all they can muster then I'm not so sure now. A 2nd hand 4080/4090 seems a much better buy, but I'll be waiting for reviews to see what's what.
Help us AMntel, you're our only hope! And yes, they should combine, because Arc needs a ridiculous X3D CPU to perform it's best.
But when gpu load is near full, it consumes way more power then the 30 seriesDon't forget the extra power consumption factors in too. It's not like these are more efficient than 40 series, they certainly are not whereas 40 series is more efficient than 30 series for power.
No I wanna see the reviews hopefully they won't be to in price ..You don't believe Nvidia official benchmarks?![]()
Heresy!!! And wouldn't you want to see the Frankenstein's monster GPU they'd create? Terrible CPU overhead AND priced too close to Nvidia? The possibilities!You do know you can buy a CPU from AMD and a GPU from Intel? They don't need to "combine"![]()
Wow to both of those! Can’t wait for reviews, even just for the thermal and acoustic performance.
2025: £2000+ for a 5090 to play games on my 480hz Oled![]()
Yep - and whats worse is, £2500 in 1999 money is £1128, so really a new graphics card today should be around £400-500 (If £180 back then) - shows how much we're getting mugged over!
30-35db quoted is quite a big range - wonder if they're accounting for variations in ASIC quality/voltage on each card, or fan issues.
If it's closer to 30db, I'll get a FE, as no point having a huge Astral if it's just as loud as the FE with 4 fans.
How is it so far? I have had my eye on that one and the ATX 3.1 Corsair RM1000x. Both see. To be pretty well reviewed, but the NZXT is 200w more and slightly cheaper.
