- 21 Jul 2005
- Officially least sunny location -Ronskistats
Add in an AFMF fake frame and FSR4 might be the new launch rework
It'll be hilarious if AMD pulled their segment to raise the price because it's better comparatively than they expected
Because that's essentially an own goal as they could have generated some massive mind share and win
Add in an AFMF fake frame and FSR4 might be the new launch rework![]()
I saw it as being pulled for either being pants or, as you say, better than they thought and pondering if they could muck it all up by increasing the price.It'll be hilarious if AMD pulled their segment to raise the price because it's better comparatively than they expected
I suspect AMD is waiting until Nvidia is committed to a price and then they can set a competitive price relative to that.I saw it as being pulled for either being pants or, as you say, better than they thought and pondering if they could muck it all up by increasing the price.
They did last time around, so I guess they will.Will OCuK be stocking the MBA cards? They look best to me and smallest.
There's usually a very small amount of AMD MBA cards at initial launch into the retail channel. I can only suggest if you want one try and buy one as soon as you can. Historically MBA cards have not continued to be sold after the cards initial launch into retail channels. So probably only one production run for the initial release of the new generation of products.Will OCuK be stocking the MBA cards? They look best to me and smallest.
The goal is in front of them and rather open..
This is true for many games past and present, high and max is so little in it static and in motion.@RavenXXX2
If those charts are accurate this will be a brilliant 4k card, lowering settings to High from Max gives very little visual compromises but vastly improves performance this could be an amazing 4k 144hz card.
Honestly if AMD price this right I think i'm going to go with a 9070XT this time round, I was going to get a 5080 but i'd rather save the money and upgrade my CPU a little sooner. I also think the 5080 may struggle to hold up over time with only 16GB Memory, yes this also applies to the 9070 but that will be a significantly lower price.
@RavenXXX2
Even I'm getting excited this time. And, the reason is because AMD have a genuine opportunity here to begin their journey to another Ryzen moment. The GPUs dont need to be blazing fast, but they DO need to be priced PERFECTLY. I really hope this is the reason that AMD pulled their presentation and that they realised how important this opportunity is. I would imagine its been quite a stressful couple of weeks for AMD - if they mess this one up then some people need to get the boot.People seem to be getting excited at every rumour of higher performance. I just see the price going up if true.
Those charts, regardless of their autheticity and accuracy, do make one thing apparent. While decent at 4k, it does seem as though the 4k performance is relatively less consistent against previous gen AMD GPUs. And to me it looks like it's the lower 16GB of VRAM that seems to be holding the 9070(XT) back, when compared to previous gen.
It's still nice performance if real, but it would have been nice for AMD to put a bit more VRAM on these, to help them handle future 4k titles. Almost feels like they're taking a page from Nvidia's book, by not increasing VRAM capacity from last gen (when comparing 9070xt to 7800xt).
These cards need to come in at £299 and £349 otherwise they'll be a failure. (Feel free to quote and alter the prices to fit where you think they should be before you declare AMD incompetent)
