Sorry, how does that help if they dont like to be used under 5degC?You can get them with a water collection box in the door.
Having used both condenser and heat pump dryers, do heat pump dryers shrink clothes like some condenser ones?Just replaced our 5 year old Hisense Heat pump dryer with a newer Hisense Heat pump dryer. Our dryer is on pretty much all day, every day (family of 5), so we definitely noticed the difference in running costs compared to an electric condenser/vented.
Yes, they take longer to dry a full load than a condenser - we previously had an old gas powered commercial dryer, which was incredible (a 10kg wet load took 20 minutes to dry fully!), but the parts to fix it were going to cost more than the entire, new heat-pump machine.
Don't be afraid to use the "ready to iron" & "linen storage" settings - the only things we run completely dry are the kids' school polos & my t-shirts, as they're folded and put in drawers. Anything that hangs in the wardrobe or needs ironing is okay to not fully dry.
I was referring to the issue of no drainage. Mine is in a unheated utility area, and I've not had any issues with it.Sorry, how does that help if they dont like to be used under 5degC?
ok, that makes more sense.I was referring to the issue of no drainage. Mine is in a unheated utility area, and I've not had any issues with it.
Thanks for posting this, exactly what I was after. Do you know what the maximum load is when running?You'd be pretty special not to get a heat pump. Mine costs pennies to run and its on all the time.
Edit: data
<1kwh for a load. Where it exceeds 2 is where it has been used 2 or 3 times in the day.
I have solar and battery with an inverter which allows 2.5kwh draw.
That's the last month of usage; it never exceeds 550w
Ah mate honestly - we were doing the clothes horse + dehumidifier nonsense for ages. I was so glad to retire the clothes horse to the shed alongside the ironing boardI’ve been using a Meaco Zambezi to dry our washing until seeing this thread. Samsung heat pump drier ordered. If nothing else we gain our dining room back from the airers.
. The dehumidifier went on Facebook when I realised I wasn't even sure what problem I was solving (and opening the windows more often with the heating on solved the moisture problem).
 Likewise, I went down a humidity spiral in our old place (Victorian terrace and then had a cabin in the garden) so ended up with a compressor dehumidifier and a desiccant. In this place, they just don’t need to be on unless washing so might as well get the space back... you are using it in the heated kitchen/utility room ? so in aforementioned unheated utility you'd expect it can scavenge less room heat, & either take longer or use more electric.That's the last month of usage; it never exceeds 550w
I am open plan at the moment (I missed the ambient temp being high enough to paint the interior doors out in the workshop.. you are using it in the heated kitchen/utility room ? so in aforementioned unheated utility you'd expect it can scavenge less room heat, & either take longer or use more electric.
(this is like bev's ....)
 so no door to living room or WC for the last month or so lol) - so it is a solid-brick wall utility room with concrete uninsulated pad but it is pretty much always at 18 or thereabouts. I try and get the second load in as quick as possible to avoid having to heat the thing from zero again.we have a heatpump drier and compared to our old condenser it is night and day interms of energy use. it uses a fraction of the power of the old one.Want to buy a tumble dryer but not sure what to go for.
Heat pumps are efficient, but expensive. And have read mixed reviews on them - some say they're the best thing ever, others say they're a waste of time.
Vented are cheap and simple, but require a vent. (I've only ever used a vented).
So thought about the condenser option. Are these on par with a vented machine, and just collect the water instead? Or are they worse with drying times etc?
Your thoughts are welcomed!
That’s not how that works, physics init.The heat pump dryer is taking heat out of your house to do the drying .. so even if immediate electric bill is less it's taking some kwh's of energy from your house too,
albeit the gas is only 4/5p / kwh, so net cost is less than condensing ...
possibly a close call if you were always drying overnight on octopus ev rates.
