Here is a good site to compare mouse shapes btw:
EloShapes - Mouse Comparison Tools
Find and compare the shapes and specifications of more than 1000 gaming mice to find the perfect one for you!www.eloshapes.com
Trust Amazon to deliver it at 8:30am right before work yet all other parcels come at 5-6pmIt is superb indeed!
All updated, didn't realize there were so many buttons and customization, unreal.Check for firmware updates for both dongle and controller too, controller needs to be in USB for it to be checked too btw via the Gamesir Connect software.
I'm not one for buying keyboards just because. Plus there's nothing actually wrong with my Shine 2. (If anybody wonders about the longevity of Ducky keyboards, I've been using it for almost 12 years).The new yet unreleased Ducky One X with Cherry's new MX Multipoint Inductive switches
I like it better than the One 3 Pro Nazca Line and that was my fav keyboard up to now.
It's tri-mode connection, inductive switches are low power so charges should last longer, web browser based software which is cool too.
But for some reason, that keyboard does seem particularly tempting. You say it's not released yet? Probably a good thing.
What's the feel of the switches like?
It feels like hall effect switches, similar sort of linearity but with a more progressive rebound spring which dynamic as the lower you go on the throw the stronger the spring resistance is which feels rather nice. When bottoming out the slap is well damped and it feels like something refined I'd say compared to my other board, the Ducky One 3 pro Nazca. Weight diff is 1.6KG here vs 1.2KG on the Nazca.
Sounds good, I'll keep a look out for one.
Here is what it sounds like, I forgot I have a dedicated mic I can use for some typing ASMR hah.
Impressive, you only needed to use backspace once.Here is what it sounds like, I forgot I have a dedicated mic I can use for some typing ASMR hah.
That was a good take to be fair, sometimes it doesn't go so smoothly!Impressive, you only needed to use backspace once.
Keyboard sounds good too. Even the spacebar. Even more tempted now.
Only if you are a low DPI mouser! 1600DPI here and all's nice and fluid!
