The DF video is hard work tbh. What’s the point of these AMD card comparisons.
Nvidia shills need to earn their crust. I didn't even bother watching it because kissing Jensen's butt is so cringe.
I mean, really, that’s a ridiculous take.
A ‘serious review site’ should review it and evidence that it’s **** if that is the case, not ‘ignore it’.
Yes Optimum and Daniel Owen were both impressed enough, even with the visual artifacts to say they'd use it for single player games over a lower frame rate.
Yeah it does seem promising how much better it is than the DLSS3 version… how good it is will depend how annoying / distracting the artefacts are… which is probably going to be game dependant.
PC Centric (the forum favourite![]()
) suggested that Black Myth Wukong had loads of artefacting and looked bad because of the ‘hair / fur’.
it'll be a big uplift for me either way but on a super ultrawide it'll give the card some room to breathe
Thanks buddy - watching now.
Yeah, seems like it’s really good when your base FPS is high. So I’m thinking… 80fps base and going for 3x of the frame gen. Maybe!
As pointed out by a couple reviews, the issue with MFG 4x just like the old frame gen, is it only makes sense to use when you already have a high framerate due to the latency. Using MFG to turn 30fps into 120fps feels horrible.
Anyway, here is PCIE scaling test. Basically don't worry about it - if you use the 5090 on a pcie4 motherboard you only lose 0.5% performance
NVIDIA GeForce RTX 5090 PCI-Express Scaling
The new NVIDIA GeForce RTX 5090 is the first high-end graphics card that makes use of a PCI-Express 5.0 bus interface. Are you in trouble when trying to run it on PCIe 4.0? What about x8, like when an SSD is using up some bandwidth? We've also tested various PCI-Express 3.0, 2.0 and 1.1 configs...www.techpowerup.com
CPU bottlenecks or something else? cos I kept hearing CPU bottlenecks, oh apparently you were talking about MFG then yes so MFG would perform with less latency.So I've seen a couple of places say reviewers were asked to test on 240mhz monitors and apparently the gains are not as good on screens with refresh rates lower than this. I have no idea why this would be.
I suppose it’s for the reason that @Grim5 mentioned: having 30fps and doing x4 MFG is going to be horrid because your starting point is too low.
So your monitor needs to have a really high refresh rate in order to make use of the multiplier.
True but also we know this card sucks at anything under 4k. So that suggests MFG works best on a 4k monitor, and you already have a high framerate and then you enable mfg to get 400fps or whatever, now we just need 400hz monitors to make use of the feature
if this card is true then its gonna be at least £7000 or more based on the 48GB Ada6000 card, pretty sure 8 of these in a 4u for rendering is about 200k
NVIDIA RTX Blackwell GPU with 96GB GDDR7 memory and 512-bit bus spotted - VideoCardz.com
NVIDIA preparing a workstation flagship with 96GB memory This card is said to use 3GB modules. According to a report from ComputerBase, NVIDIA’s upcoming desktop graphics card is expected to feature 96GB of GDDR7 memory. This configuration was revealed in shipping manifests discovered by the...videocardz.com
all we need to do is remove the $ and replace with £ and there you have it, UK pricesSaw this on Nvidia subreddit for MSI RRP:
- Prices: RTX 5080
- MSI Shadow 3x OC (Black) - $1119.99
- MSI Ventus 3x OC Plus (Black)- $1139.99
- MSI Ventus 3X OC (WHITE) - $1149.99
- MSI Inspire 3X OC (Gold) - $1169.99
- MSI GAMING TRIO OC (White) - $1199.99
- MSI GAMING TRIO OC (Black) - $1199.99
- MSI VANGUARD SOC (Black) - $1229.99
- MSI SUPRIM SOC (Black) - $1249.99
- MSI SUPRIM LIQUID SOC (Black) - $1299.99
- Prices: RTX 5090
- MSI Ventus 3x OC Plus (Black)- $2199.99
- MSI GAMING TRIO OC (Black) - $2349.99
- MSI VANGUARD SOC (Black) - $2379.99
- MSI SUPRIM SOC (Black) - $2399.99
- MSI SUPRIM LIQUID SOC (Black) - $2499.99
Have any reviewers mentioned under-volting and how much it affects performance? Hoping for results as good as a 4090 at 70%.
Undervolting will be your friend this generation
This review tested undervolting in one game, so more needed please but results are quite decent
RTX5090 default power profile: 133fps and 575w used
Manual undervolt 0.970v: 133fps, 490w used
Manual undervolt 0.900v: 125fps 410w used
Manual undervolt 0.875v: 115fps 350w used
So at least in this one game, you can cut power consumption by 85watts and lose no performance and if you're happy to lose 5% performance you can cut power by 165watts. But remember with the 0.9v undervolt, the performance lost now means the 5090 is only 25% faster than the 4090
