Caporegime
- 7 Apr 2008
- Lorville - Hurston
Is there any implications in running a gpu undervolted and applying a OC to it?
Yep, it was the HUB review of the Suprim. 71c stock, 80c when OCing...That's a whole lot of wattage through a single connector!
I did see someone saying that the connector on the FE was up at 80c at one point.
I'm also curious as to whether the riser issues are present on the AIB cards, since the FE basically already has a built in riser.
I've watched too many review videos, I can't remember which is which any more!Yep, it was the HUB review of the Suprim. 71c stock, 80c when OCing...
It's clown world mate.I was never going to spend £2k - 4K on a single peice of hardware.
From what I have read and watched this is going backwards for all I care.
It was only like 10 years ago people would slate a GPU with higher power requirements then previous generations AMD got slated a lot more than nvidia in this bracket.
Now people are happy to throw this amount of money at a 500w/600w even spiking to 900w
Wow... What ever happened to pushing the envelope on reducing power and gaining performance?
I guess we just live in mad times now.
That is my view on this generation.
Is that just the gpu wattage?
Tech Yes City on youtube tried that and got some good results out of it.Is there any implications in running a gpu undervolted and applying a OC to it?
The latency on those screens looks pretty good, not that many people will be able to take advantage of an FPS that high.More stuff on latency and MFG (from everyone’s favourite):
Edit - this is followed up with comments that the image quality deffo isn’t as good as native (as you’d expect).
Given the number of people saying this, I suspect demand for the 6090 to be very strongSome of these power draw figures are beyond ridiculous. Honestly feel like this is a generation to sit out. The next generation with a process node change should be the one.
yeah they looked at an issue no one would have cared about. surely putting a that in an SFF case is going to cause heat issues on components anywaySo from what I can tell the AIB cards seem to be massive, but cooler and quieter than the FE. Seems a strange decision by Nvidia to overengineer a 2 slot cooler for the flagship card. 95% of buyers will be putting one of these in a massive case, a massive case that most of us have cos the last couple of generations of card have all been massive including the FE!
I could get a 7 slot card in my Hyte case but would much rather have cooler and quieter than smaller and I would suspect most are the same.
That’s precisely what I’m going to do. 150W less and a few percent more performance according to one of the reviews posted earlier.
As my 4090FE is being given to my son I’ve got no choice but to pick up a 5090FE, hopefully at launch but I’ve got until the 9950X3D releases so fingers crossed!
Haha truly an emergency purchase![]()
Well, I think that’s sealed the deal for me that the Suprim is the one I’ll go for.
It's got nothing to do with AMD. I am pointing out that either hardware be it GPU or CPUs used to get flopped if it released with worse power draw than previous generations.
Intel, AMD, Nvidia now it's all OK to push the power with very much gain to back that up.
Compare this to Samsung S25 event, while pushing the performance Samsung also mentioned the great length it went to to reduce power and increase battery life.
O but Nvidia improved the cooling it's still runs 600w though impressive.
Suprim was hitting 600W on the connector, overclock it and it rises above that @ HUB Suprim review. Was hitting 80c on the connector as wellWhat the actual ****. How is this even possible? 761W on a single 600W cable?
