- 25 Nov 2011
- The KOP
This comment makes no sense. While I am uncomfortable with the power draw of the 5090 on a single cable you are comparing desktop parts with a mobile phone. Clearly with a mobile defice battery is a huge factor so efficency of its componets is king. With enthusiast / high end dresktop parts I couldnt care less about power draw ( as long as connectors are up to it)
Of course it makes sense. Just because a device uses battery or is wired to the wall doesn't mean power efficiency can just go out the window.
Power efficiency should be one of the main bullet points on that board when the GPU is in the design stage. It's almost like Nvidia just went screw the power efficiency.
Imagine this GPU generation without frame gen or upscale technology you be looking at some very disappointing releases for the past 5 years.
I do wounder if upscale technology is making a difference when designing a GPU these days. Nvidia seemed to talk a lot about this when comparing 5080 to the 4090 like it's ground breaking engineering.
