No tbh, even in the depths of reddit nobody seems actually agreed what specific problems it'll cause. Also, EU consumer laws would protect, and we'll probably get to piggyback off of thoseanyone bothered about the update?
Nope, bought into a more closed environment (from a HW perspective)for ease of use and for the same reason just use their software.anyone bothered about the update?
basically blocking 3rd party slicers connecting directly with the printer. you'll have to sneakernet it over.No tbh, even in the depths of reddit nobody seems actually agreed what specific problems it'll cause. Also, EU consumer laws would protect, and we'll probably get to piggyback off of those
Well yes the basic part even a cybersecurity novice like me can get the gist. When you go down the rabbithole of people discussing in detail which protocols and what and how it'll be implemented and exactly what will trigger what to happen, there doesn't seem to be consensus.basically blocking 3rd party slicers connecting directly with the printer. you'll have to sneakernet it over.
I believe at present in LAN mode you can remain without internet indefinitely. With the upcoming firmware changes and Bambu Connect nobody knows. The person who extracted the encryption key from Bambu Connect said it is only valid for a year which would imply at least annual updates to Bambu Connect would be required. Bambu have now said they will be implementing stronger encryption so anything could happen.Am I correct in thinking that even in LAN mode the printer will still require internet? Is that the reason for developer mode being required?
Thanks, that clears it up as there seems to be conflicting information everywhere. I’m gonna to stay on the older firmware and stick it on LAN mode with Orca.I believe at present in LAN mode you can remain without internet indefinitely. With the upcoming firmware changes and Bambu Connect nobody knows. The person who extracted the encryption key from Bambu Connect said it is only valid for a year which would imply at least annual updates to Bambu Connect would be required. Bambu have now said they will be implementing stronger encryption so anything could happen.
Developer Mode is for people who want to use third party software to control their printer. Things like Orcaslicer*, Panda Touch, Home Assistant and Octoeverywhere will be locked out. People wanting to continue using these will either have to stick with the current firmware or update and use developer mode. Developer mode will however lock you out of cloud integration and the phone app.
* Bambu have talked about Orca retaining limited functionality by using Bambu Connect but Softfever stated today they will not be integrating this into Orca. Linky: https://github.com/SoftFever/OrcaSlicer/pull/8103#issuecomment-2612855023
I will be sticking on current firmware until it all settles down and I know where its all at.Thanks, that clears it up as there seems to be conflicting information everywhere. I’m gonna to stay on the older firmware and stick it on LAN mode with Orca.
That was also my plan until I found Orca under Linux is rather crash happy. By itself I can live with the flakiness but it also freezes when trying to send larger files to the printer (one bug report said ~6MB was the cutoff).Same, I have also put it in LAN mode and only using Orca slicer.
It has a more complete set of printing calibrations built in and I think offers a few more options for support placement and printing overhangs.whats the advantage of orca over studio? , ive used prusa and cura slicers with my ender, only ever studio on bambu though. I thought they are pretty much forks of same program??
What are you using to seal the Ikea box? I am currently using Dewalt Tstak 2.0 boxes as they have a proper gasket seal.Elegoo PetG Rapid is good as long as you dry it first and then dry it again if you do not use it for a week.I do keep all Filament in 45L Ikea Boxes Sealed with Silica trays when not in use...
But I Bambu when I can get it when not waiting ages for delivery... But Sunlu Pla Plus 2.0 (Colour Choice is not Great) has been good for me. I always dry before use in my Sunlu S4 dryer...
How many spools can you fit in one of those?What are you using to seal the Ikea box? I am currently using Dewalt Tstak 2.0 boxes as they have a proper gasket seal.
forum.bambulab.com
