NVIDIA RTX 50 SERIES - Technical/General Discussion
This is one of my issues with MFG ; you need a good frame rate before using it otherwise the latency and visual artifacts are distracting. In this video Tim is recommending a base frame rate of 100-120 fps, or 70-80 fps at a bare minimum depending on the game/genre. For me personally, if my game is already running at 4K/120 fps then I don't need or want MFG on top of that.
Thought PC gamers were 120 FPS master race or GTFO?
"MFG is good when it makes least sense to use it"
  • Like
Reactions: ne0
5900X (AM4) with 3090 Suprim X
42"Oled so max 120fps (C3)
Is it Used 4080 Super, Used 4090 or New 5080?
Or
Just stick?
What's the thoughts and what are other 3090 owners doing at this point?
I don't get why you say no warranty? I know the FE doesn't transfer but the majority of AIB's do as the warranty is on the card and not the purchaser.
What AIB? As far as I know only EVGA had transferable warranties and they are gone now.
Good video. Summarises the issue with FG and MFG well. To the point of have a base frame rate of 100-120fps, good luck achieving that in the latest AAA games with all the bells and whistles turned on. Not even DLSS performance will save you in many cases.
You’ve got AMD with cards in stock and not launching till march and Nvidia launching in January despite having no stock, what strange times we’re living in.
it's like some weird April fools joke that only billionaires are laughing at.
I swear Jensen and Lisa Su are wetting themselves with laughter at our expense.
Yep completely useless feature. If anyone else finds value in MFG or Frame Generation, then good for them, but imo frame generation is not worth even paying $1 for
I do like frame gen if the base is good. Smoother panning is better part of high fps than latency (which I never have a problem with).
