Dam the controls, Were they really that bad when i played it back in the 90's on a playstation![]()
One thing i noticed is the camera is much closer in the remake compared to the original when you look by pressing the button to flick between the two versions.
In a very strange & weird way i feel the bad controls & very bad camera angles is kind of what made TR1 so good all them years agoA lot of games from the early 3D era have aged badly.
Things like controls and cameras have really improved immeasurably. In fact, IMO, those are a bigger barrier to enjoyment of old games than graphics.
Yes this. The movement defines the game.I like the clunky controls. I only recently tried the reboot franchise, and felt like I wasn't in control - more like I was guiding Lara through set pieces. The specific need to place Lara exactly where required in order to execute the moves is what made the (early) games enjoyable as it turns out.
Yes and keyboard. Me and my Dad played through all of TR1 and 2 on keyboard.Think the biggest problem with the controls is that the first PlayStation gamepads didn’t have joysticks on them back then, So am thinking the controls were designed to use four buttons instead of a joystick
They had the digital D-pad which was a pain the joysticks made things easier but that was laterThink the biggest problem with the controls is that the first PlayStation gamepads didn’t have joysticks on them back then, So am thinking the controls were designed to use four buttons instead of a joystick
Are you using modern controls or tank controls?Dam the controls, Were they really that bad when i played it back in the 90's on a playstation
I keep running into wallsand turning around on the spot is a real pain
Am using an xbox elite series 2 gamepad.
I may try using an old xbox 360 gamepad to see if that makes any difference,
Would really like to try using a playstation 1 gamepad but i don't have one and also don't think it would work on a pc
Go full keyboard. It was fully rad back when I played it in 97!Dam the controls, Were they really that bad when i played it back in the 90's on a playstation
