I have a 4K VA TV that always has a noticeable improvement with HDR on. For my IPS Ultrawide, HDR is somehow absolutely revolutionary in games.
I recall someone making a point regarding OLED, about its infinite contrast ratio being redundant when the lowest brightness pixel on the screen is 1 nit / not absolute pitch black. Between 1 nit and maximum brightness, suddenly OLED's contrast is average at best.
Sounds like OLED can't yet replicate the spectacular almost wince-inducing mega-brightness HDR on IPS can. My VA TV also can't quite do mega-brightness, but on the other hand its blacks are basically OLED-like to me and its still spectacularly colourful, like my IPS with HDR on.
Maybe I'm just lucky having a top drawer VA TV and IPS monitor respectively. Either way, I'd say having OLED is definitely not a pre-requisite to getting game-changing HDR.
RTX hdr is just another killer feature on nvidia for games which don't support it![]()
Life's too short to be manually tweaking values for nugatory gains. I think I read there is an fps hit but that hasn't been a problem on any game I've played.I tried AutoHDR on Win11 but the nVidia RTX HDR filter has more adjustability so tends to work better.RTX hdr is just another killer feature on nvidia for games which don't support it![]()
Same 9 times out of 10 HDR makes the game look washed out and worse. Don't get me wrong when HDR works correctly its amazing. But getting it to work is the problem. With the opposite of dynamic often being the case. Often its not a problem with the screens, its a problem with how windows implants and fails to correctly switch over to the HDR profile for games. Yet will work for YouTube videos.I've never figured out how to get HDR looking right on my PC games. It always ends up looking grey, the opposite of dynamic.
Yes it's annoying how in consistent it can be implemented.Same 9 times out of 10 HDR makes the game look washed out and worse. Don't get me wrong when HDR works correctly its amazing. But getting it to work is the problem. With the opposite of dynamic often being the case. Often its not a problem with the screens, its a problem with how windows implants and fails to correctly switch over to the HDR profile for games. Yet will work for YouTube videos.
You may be onto something there, I've owned HDR capable monitors for several years and always thought nothing of the HDR on it when I turned it on, very underwhelming, couldnt see what the fuss was about. Recently I bought a really good OLED monitor and HDR since then has been amazing in the games that I've tried it on, having said that, just the move to an OLED made a big difference to the look of my games (with or without HDR)I honestly think it's more a case of very few people having the equipment to really appreciate it.
The vast majority don't own an OLED or even a LED with FALD and decent peak brightness etc, most are on cheaper tv's and monitors that claim to support HDR at best but in reality don't.
Makes me think of "HD-Ready" TV's back in the day that would only do 720P rather than 1080P.
AI is pretty bad, seeing and shooting you a lot better than it should. The whole games feels, overall, too dark, like the GI is missing a few bounces. That as non HDR content.I came to this conclusion after playing STALKER 2, which makes particularly good use of HDR (albeit exaggerated by using auto exposure too). Beyond the purely aesthetic effect of making things brighter and more colourful, it can actually have an effect on gameplay.
Are there any other games where turning on HDR affects gameplay?
- Assuming a bright enough monitor, it makes lighting part of tactical decisions, for instance it becomes a disadvantage to attack someone while facing into the sun, or to look at a bright light while creeping through the dark.
- Increased bit depth makes it easier to see in the dark by adding more shades of grey instead of everything dark becoming black.
HDR enabled, auto-off, then tweak, as shown here:When using RTX hdr should windows auto hdr be on or off?
Yes, but I believe it is minor, and the consensus is the visual improvement is worth it.Does RTX HDR still affect frame rates when Auto windows HDR doesn't?
