- 26 Dec 2003
- Cambs UK
All while conveniently carrying only 1 shell (cartridge??) and a sausage when you get round to looting them
The RTX options don't show in the few versions of Inspector that I've tried. Do you have perhaps a link to someone that does work?GSC said on discord that they are "very soon" releasing another patch as this one is only a hotfit, the next patch is the winter major patch and contains a lot more struff. Here's hoping Hardware RT and DLSS 4 is baked in too.
For now you can manually swap in the DLLs and as people have found, DLSS Performance now looks better than the old DLSS Quality:
Be sure to enable profile J as well using an updated fork of Profile Inspector:
You can use the Revamped version which has it:
GitHub - xHybred/NvidiaProfileInspectorRevamped: NVPI Revamped - A better oragnized, documented, user friendly NVPI fork
NVPI Revamped - A better oragnized, documented, user friendly NVPI fork - xHybred/NvidiaProfileInspectorRevampedgithub.com
Although I would ignore my screenshot there since I am applying the preset to this game only, you can just apply the global setting instead to the base profile instead so all games with DLSS use Profile J, you will then have to go into each game folder and update the dll file of course to v310.
Do you know if this will be rolling out with the upcoming official drivers and new DLSS?You can use the Revamped version which has it:
Legend. ThanksAll this process is supposed to be until the new driver and new update to NV App is out which lets you directly swap DLLs and enable DLSS4 correctly. We will have to wait and see how that plays out as nobody knows just yet but it does sound like this new update will take away the need to manually swap DLLs and use profile inspector.
146 and didn't know this, doh!I've been playing for 97 hrs and just discovered that
there is a fast travel facility, found it by chance when checking out the glowing orb in Rostok , so now have to figure out all the other such portals I missed in other places.
i thought there were already fast travel guides you can talk to?I've been playing for 97 hrs and just discovered that
How do I download this with the .exe? From the code button / archive, there is no executable in itYou can use the Revamped version which has it:
I never used a guide either, so I've no idea what they do...perhaps this wasn't one of my better decision.i thought there were already fast travel guides you can talk to?
although I never used one
