Logo animation scroll effect
6 Jan 2006
Newcastle upon Tyne
Could someone point me in the right direction of how to achieve a logo animation scroll effect please? Searching for "logo animation scroll effect" doesn't return what Im looking for.
Here is an example of what I want to achieve, if you scroll to the very bottom the Altgage logo changes colour as you scroll. Looks to be circles behind the logo that expand as you scroll.
Thanks.
Looks like the shape of the logo is defined in .svg as a negative, then there are four divs behind it defining the circles that appear. These circles get their size changed by hooking into the scroll event on document, and setting a transform on the four divs from there. The javascript part of it has been thoroughly minimised so I'm not sure the exact details, but that's the basics of it.
Following on from what @Mr Jack mentions, it's animated using the GSAP libraries, specifically Timeline and ScrollTrigger, to control the CSS transform scale function of each 'circle' (DIV containers have the class 'footer-logo-circle' and then 'circle-1', 'circle-2' etc).
From what i can tell the JS (Javascript) is within https://slater.app/6660/12816.js and is defined in the 'initScrolltriggerAnimations()' function -
Code:
if (document.querySelector('.section-footer')) {
  $('.section-footer .negative-footer-logo-box').each(function () {
    let triggerElement = $(this);
    let targetElement = $(this).find('.footer-logo-circle');
    let tl = gsap.timeline({
      scrollTrigger: {
        trigger: triggerElement,
        start: "0% 90%",
        end: "100% 50%",
        scrub: 0.25,
    tl.fromTo(targetElement, {
      rotate: 0.001,
      scale: 0,
      rotate: 0.001,
      scale: 1,
      ease: "none"
This essentially seems that once the 'triggerElement' (in this case '.negative-footer-logo-box'; the negative SVG logo) enters the viewport, boundbox is created by the 'start' and 'end' (values are 'top bottom') values, the 'targetElement' (each of the circles DIV containers) begin scaling from 0 to 1 (CSS 'transform: scale(0, 0);' to 'transform: scale(1, 1);').
Might be best to throw the HTML and JS into Codepen.io, include the GSAP libraries, and see if you can replicate it.
Yeah that's exactly it, get the document height, get the current scroll offset, and determine the intersection point with the remainder value being used to drive the animation timeline. @Mark M what're you implementing this in? are you using React?
The effect is also quite dependent on the scroll behaviour being smoothed, in the linked case they do that awful thing of hijacking to make this consistently smooth across browsers but it feels pretty terrible most of the time.
Rough workout with CSS and Java, bit rough, logo at bottom left.
Code:
    Layout = "~/_SiteLayout.cshtml";
    Page.Title = "Home Page";
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="width=device-width, initial-scale=1.0" />
    <title>@Page.Title</title>
    <style>
        .logo-container {
            position: fixed;
            bottom: 20px;
            left: 20px;
            z-index: 1000;
        .logo {
            width: 100px; /* Adjust as needed */
            position: absolute;
            transition: opacity 0.5s ease;
        .content {
            height: 2000px; /* Just to make the page scrollable */
    </style>
</head>
<body>
    <div class="logo-container">
        <img src="~/images/logo1.png" alt="Logo" class="logo" id="logo1" style="opacity: 1;" />
        <img src="~/images/logo2.png" alt="Logo" class="logo" id="logo2" style="opacity: 0;" />
    </div>
    <div class="content">
        <!-- Your page content here -->
        <p>Scroll down to see the logo fade.</p>
    </div>
    <script>
        window.addEventListener('scroll', function () {
            const logo1 = document.getElementById('logo1');
            const logo2 = document.getElementById('logo2');
            const scrollPosition = window.scrollY;
            const scrollThreshold = 500; // Change logo after scrolling 500px
            // Calculate the opacity based on scroll position
            let opacity = Math.min(scrollPosition / scrollThreshold, 1);
            // Set the opacity of the logos
            logo1.style.opacity = 1 - opacity;
            logo2.style.opacity = opacity;
    </script>
</body>
</html>
Thanks for the input all, I've got a mock-up (almost) working on a test site so a couple of tweaks should sort it.
Doesn't work properly on mobile, Firefox pixel8.
Imo this sort of effect isn't worth doing.
I know where you are coming from but Im looking to make a site that stands out a little without being Lingcars type crazy :D
