so the tc100....
1 Mar 2024
Leeds
i got tc100 and its been fine but im now finding after a hour the foam in the bottom as flattened out and im just sitting on hard plastic.
id like to not have to replace it... less than 4 months old
is there any shops that sell seat pads for gaming chairs.
i am a big lad 6"2 no fat but 110kg so... its probably me and not the chair.
when you grab the base the foam(or whatever) lair can be lifter and you can get your hands under it so even a good foam or pad that i can put under it for extra padding ?
Less than 4 months old and already knackered, open a warranty claim and get it replaced.
I had exact the same chair and had the same thing happen. Just got rid of it yesterday and replaced it with a chair that has a strapped base rather than a solid board of metal/plastic.
I'm also 6ft 1 and 16st.
Have a look at the ANDASEAT mavity Gaming Chair from a certain purple shop. Fantastic chair.
i went to a big brand shop that i got the chair from and was talking to the guy in there, when i explained why i wanted anew chair, he said RMA it and just get a replacement.
the chair as a 3 year warranty he sais just RMA it ever time it get bad for the next 3 years hahah. so i did
I’ve got the Corsair T3 Rush. Does yours rock back and forth a bit when you lean back. It’s not too bad and I can’t recall if it did it from new. I’ve had it just over a year.
yer but only a few cm say 3cm at most. but i feel this is normal??
how do you feel the foam is in the base?
Brought mine over a month ago so no issues yet but have noticed foam/padding a slight sag after an hours use - it does return to normal after awhile of not using it.
How much did you pay for it ? Your height and weight you need the larger XL version of the kaiser or Secretlabs.
