9 Feb 2025 at 13:47 #1 Zeebedy Zeebedy Soldato Joined 28 Jan 2011 Posts 8,535 Hey guys, Pc up and running sweetly now. The only one thing I’m curious on is, sometimes it takes a good 15-20 seconds to shut down, sometimes faster? Any idea on this? Or is it normal?
9 Feb 2025 at 14:11 #2 WARburton WARburton Associate Joined 1 Mar 2024 Posts 2,252 Location Leeds Zeebedy said: Hey guys, Pc up and running sweetly now. The only one thing I’m curious on is, sometimes it takes a good 15-20 seconds to shut down, sometimes faster? Any idea on this? Or is it normal? Click to expand... my assumption would be its saving info that's in ram. and or if you SSD as DRAM there would be info saved to it that need to be offloaded
9 Feb 2025 at 14:15 #3 Zeebedy Zeebedy Soldato OP Joined 28 Jan 2011 Posts 8,535 WARburton said: my assumption would be its saving info that's in ram. and or if you SSD as DRAM there would be info saved to it that need to be offloaded Click to expand... Ahh, ok. Thanks for the info on that!
9 Feb 2025 at 14:16 #4 WARburton WARburton Associate Joined 1 Mar 2024 Posts 2,252 Location Leeds Zeebedy said: Ahh, ok. Thanks for the info on that! Click to expand... if its a new build, and your installing stuff it make this happen, but ones your all set up it will be much faster
