Word 2013 Export pdf Issue
26 Feb 2004
Hampshire, England.
Hi guys,
I'm having an issue with a workstation I use periodically... Basically any Word docs I'm working on that I then try to export through Word as a pdf convert but docs but with mad corruption! What's outputed is readable but not presentable.
I've repair installed Adobe Acrobat but that doesn't fix the problem.
Just wondered if there was any quick fix?
Thanks!
Have you tried print as pdf? Does that get mashed too?
So, I tried your suggestion, that produced a normal pdf and then I tried to use my previous process and that's now working too... I did do a restart in the middle of all that, so I'll never know :D
Thanks guys!
