- 29 Sep 2010
- Cumbria
I had no choice as new install... how can I unisntall it and go back to 23..... it absolutely sucks.
You will need to do a fresh install with a older version of Windows (23H2), this may help locating one. (Rufus only offers 24H2 now)I had no choice as new install... how can I unisntall it and go back to 23..... it absolutely sucks.
I did try that and didn't work didn't notice I also needed the other app as well. Teach me for not reading and just mashing the refresh button.You've put a lot of effort into doing it the hard way! Yup, 24H2 is the latest. Download and run the Windows 11 Installation Assistant to do an in-place upgrade.
Its only going to be safe to install once they remove recall from it so until this happens the answer is no!I was just about to ask if this is safe to install yet, but I've just checked Windows Update and it looks like it's just installed in the background and is pending a restart, so I guess I'll find out soon enough.![]()
Turns out it actually hadn't installed yet so I paused it and have just done the policy change featured in the video @freddie64 posted to remain on 23H2 for the forseeable.Its only going to be safe to install once they remove recall from it so until this happens the answer is no!
Don't blame you, Didn't see the video but also done the same.Turns out it actually hadn't installed yet so I paused it and have just done the policy change featured in the video @freddie64 posted to remain on 23H2 for the forseeable.![]()
I used the Chris Titus tool to disable recall on my 24H2.It’s only going to be safe to install once they remove recall from it so until this happens the answer is no!
Yeah, even though its disabled its still there and god knows when Microsoft will decide to activate it without you knowing via a Windows update and it left to its own devicesI used the Chris Titus tool to disable recall on my 24H2.
I think a lot of people have had the same experience and done the same thingI updated and had issues. I went back to 23H2 and I'm staying here
