Show off your 5090s thread!
Quick pic. Was having buyers remorse with the Palit 5090 as posted on other forum. So I slapped myself and got to work. Put new exhaust fans with PWM (as only had spare non pwm to start with and was too loud), as had an AIO 4090 mounted in roof previously, then mounted the card vertically. Feeling better about it now and plan is to put a water block on it, and the Heatkiller which fits this looks really good.
Fancied an Astral for the monitoring, (Asus fan boy), but can keep an eye on it manually (;)). Hopefully there are no 'spare' Astrals on next weeks drop...:rolleyes:
Loving the digital clamp meter m8 :D
That actually doesn't look that bad, does the card have RGB on the front or is that reflections from the other lights?
Front. I just think its fugly and was pwr limited a lot re 575w on gpu z. Gotta go...
Fair, I've noticed a lot more stock, so if you're not happy with the Palit then you won't have that much of a hard time finding another
Yeah- not having much luck with Autobuy. Missed the TUF pre order yesterday (6), but now sitting at 1. Hopefully OC wil have some spare Astrals when they get them...
