- 19 Feb 2006
- West Mids
Pulse XT is live, but the website has also fell over unfortunately.
I set 238fps for min and max on 240hz monitor, GPU won't pass that. The minimum value part of it has never worked right for what I play, I think its crap at recognizing gameplayCool and Quiet is another level of functionality, it dynamically sets GPU load to keep an optimum FPS, you can even set what that optimum is, say its 100 FPS, if need's to boost power to achieve that it will boost power, if it only needs low power to do it it will reduce power, it a good one button way to keep with in a desired range and have the software deal with clock and power requirements to hold that range.
It not pumping 1000 FPS in menus is a side effect of its purpose.
sameI got my payment in before 13:58 but got stuck after hitting pay now! Doesn't look good![]()
