*** The AMD RDNA 4 Rumour Mill ***
Yup there's what £30-£50 difference? Pointless going for the non XT
If the non XT was £100 cheaper yeah that's ok
I thought that then I bought one as it will at least fit in my case :cry:
Looks like if you're lucky with silicon you can up the power limit to 110% and get just about XT results in gaming. Somebody posted a vid link earlier, can't remember where.
But yeah if you have the space the XT is an easy upsell. (e: at 569 anyway)
Thoughts on a 2080ti to 9070XT jump for 1440p? In all fairness the 2080ti does fine for what i want but im thinking i can prob get a £200 for the 2080ti? and throw £350-400 at a 9070xt for a cheapish upgrade? Just not too sure on how much of an uplift i'll see. I'm not too fussed about RT
According to technpowerup, +87%
Got my Nitro through this afternoon, really happy with the limited time I've had already, managed to dig out my old HD4870 from the last time I had team red, just shows how big these things are these days.
Setup has been really straight forward, from the few tested games so far it's been a pretty sizeable upgrade. Helldivers 2 is double, Dragons Dogma 2 is double with ray tracing now enabled, Returnal is about double with ray tracing now on. I had a little notepad with some random games tested so will post some results at some point. Not clocked it up/undervolted yet, I'll have a go at that over the weekend. Temperatures are really good, it's barely been over 60c so far and is practically silent as well.
Edit* @Zenduri I've come from a 2080ti as well ^
Apparently I was misinforming people that the reaper runs too hot 90C is toasty even if it is within spec- will hurt the vram long term- imagine putting your finger next to a boiled kettle at 90C for hours- eventually you get burnt? :D:D:D:D:D:D:D
lol, yes it was me who told you off and here you are still spouting the same FUD. If this was school you would be getting extra homework for not listening :D
GDDR6 is rated up to 105c and possibly even 120c
My 3080 FE would hit 95c regularly and even over 100c on occasion. VRAM will not fail if run at these temperatures for hours because a GPU will thermal throttle itself. There were 3000 series owners who bought new thermal pads and had to dismantle their expensive GPUs to install them. All to get temperatures as low as the 88c - 92c you guys think are “too hot”.
A bit of advice, if you are sitting with your finger against a GPU while gaming for hours, you need to go see a shrink for the self harming ;)
Incidentally, you will begin to suffer burns at about 45c. So even if your VRAM is running at a nice “cool” 75c, holding your hand against it for hours will cause serious burns. Please don’t do this ;)
Just for clarity, 90c on VRAM is not “too hot” and will not cause any long term damage as you alluded to. Well unless you are holding a very sensitive body part against it :)
Looks like some sort of mounting error with the cooler
Yea ^^That^^, typically you'd expect something like a 10-20°C delta between GPU and hotspot.
I wouldn't be surprised if it's also down-clocking on occasions as, unless it's different for RDNA4, it will throttle around the 115°C mark.
From X again..Guess which is FSR3.1, FSR4 and DLSS4 ...
GlYUFH8XAAAluFi
EDIT: FSR4 is on the left and DLSS4t on the right.
Any coil whine?
IDK FSR4 was developed with the help of Playstation, makes sense but it's always nice to see companies working together for the benefit of consumers.
