I have a TP link 8 port ethernet switch which has 5 ethernet cables plugged in.
My broadband connects at 500mb and the switch appears to share the bandwidth evenly.
If I unplug 4 of the cable the one connected gets 500mb. But as I plug in additional cables the bandwidth appears to be split evenly.
Is there a switch that just gives the ethernet cable with a device using bandwidth the maximum until another one comes on line to use some bandwidth.
Scenario:
5 rooms each with a wall plate for an ethernet cable. All connected to the TP link 1gbps switch.
My office will get the full bandwidth if it's the only cable plugged into the switch.
Is there a switch that can have all 5 cables plugged in but provide the maximum bandwidth available when devices are connected.
The other 4 cables connect to other rooms that connect to TV's. If I'm not using any devices in those other 4 rooms I'd like the office to use the maximum available. Currently it just splits the 500mb automatically between all 5 room.
Lee
Scenario:
Lee
