Tabletop Warhammer?
Bit more progress on Lord Felthius And The Tainted Cohort,, bits to tidy like the gun, but enjoyed painting these, a lot (also another 2 flesh tearer terminators)
Do any of you use a Dremel or similar multi tool when cleaning up models or terrain?
I was going to use a knife and files as needed, but I've just found a couple of dremels that look like they could also do the job.
I won't be able to try it out anytime soon since there's no space to work, but I can set the tools aside for later if they are worth using.
Edit - search is my friend. Looks like the Dremel might be too bulky so I'll put them out of the way and revisit it if I get fed up with the knife or fancy a change.
You probably found it but that was what my landraider picture was about in regards to DSPIA grinding pen.
@kindai Old scheme apparently but it's tempting me as I have coloured metallics..
Almost at a point now where I’m happy to progress the scheme of the BT onwards to batch painting. Apart from the colour of the aquillas. 100% want red gun casings and chain swords. Would love to paint a few swords as power swords but plain steel is so much better looking for BT’s
I like a mix of retro/Blanchitsu.
drill those barrels!! It’s makes so much of difference
I really wish I had not watched that Youtube video, ordered 12 colours of the Scale 75 metal alchemy paints plus the Vallejo metal colour duraluminium paint this afternoon ;)
Made a start on my fire dragons.
Some of the bits to black out are tricky but I might just ignore them because I can't see them unless I look up inside the model.
Oh and new inks for some stuff I want to try. I got a lot of fluorescent stuff en route.
Well it happened.
That’s ones fabulous order :D
That cleaning kit has enough to get you started if it’s the standard spray cup, needle thing and a few pipe brushes.
At a later stage I can recommend the H&S service kit. Better quality tools, brushes and seals.
Also pick up some dental brushes. They very handy for cleaning.
Hey all, finally caved in this morning just ordered the Emperor's Children army box set from Firestorm Games ;)
He caved in to the FOMO!
You'll have them assembled and painted before I've decided on a colour scheme.
Just got shipping Confirmation :cool:
Also received a bag of 10x bases today from GW. In a box that could have fitted about 50 bags.
Happy Birthday Dude :D
My EC is arriving Saturday so probably won't do any assembly until Sunday as I'm playing 40K Sat.
